Hi,
babbittd - This may assist in your ponderings, this excerpt is from an article in LUBE REPORT, Volume 12, Issue 14 from 12/4/2012 concerning Daimler AGs lubricant development programme, it gives some insight into the needs of continuing lubricant development.
“The upgrade is also awaiting completion of a CEC bench test for low-temperature pumpability of aged oils. Such a test became a priority for European automakers after a rash of engine failures suffered in Europe during an extreme cold spate in the winter of 2008-2009. The failures were attributed to engine oils that turned to gel.”
