When you say it won't crank, is it seized??? Will it rotate but won't start?? I never seen a valve get stuck which wasn't inactive for a long period. However that engine being a flathead, you can look in the sparkplug hole and rotate the engine and see the valves moving.No compression, maybe head gasket blew. Flywheel keys will affect spark timing, not compression.
