BW-44-44 Transfer Case special fluid
by -SyN-
06/25/16 02:27 PM
mini inspection camera for androi phone
by bmwjohn
06/25/16 02:15 PM
Cause of noisey serpentine belt
by 007
06/25/16 01:48 PM
Purolator Boss 14610 C and p
by bbhero
06/25/16 01:33 PM
Ear hair - remove, ignore, trim ???
by Mr Nice
06/25/16 01:04 PM
Best Oil for [censored] Intek 19 HP Mower
by beadvised
06/25/16 12:43 PM
by bbhero
06/25/16 12:42 PM
Was the original Mobil 1 a Straight 20?
by Gene K
06/25/16 12:23 PM
Valvoline Maxlife 0w20 Synth blend?
by HKPolice
06/25/16 12:11 PM
Walmart Canada (GTA) Valvoline MaxLife 0w20 $18.88
by HKPolice
06/25/16 11:49 AM
Makita B04510 Palm Sander - Fix?
by user52165
06/25/16 11:41 AM
Red Arrows
by Whitewolf
06/25/16 11:20 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
79 registered (86cutlass307, -SyN-, 360kid, 69GTX, 007, 2015_PSD, 10 invisible), 2027 Guests and 11 Spiders online.
58257 Members
66 Forums
250798 Topics
Page 1 of 2 1 2 >
#3467599 - 08/28/14 03:40 PM My 98 Monte Carlo z34
clarkflower Offline
Loc: US
I just bought the 98 Monte Carlo z34 with 109,000 at a charity auction. It is the 3800 Series II One owner So Ca and it seems to have sat for 2 years. I was actually able to talk to the owner prior to buying and he said he did all the maintenance (yet 2 old open recalls were not done-steering and engine fires) so I don't really know. He also said the emergency flasher button broke and the blinkers stopped working.
I took the car to chevy for the recalls and an oil change
Do I do a transmission flush or a change? (I know old bmw's-they say not too as they start to slip)
Do I do a coolant flush or change
Issues:The car gets stuck in park and I have to pull up the console cover and push down that button. The button on the shifter seems to be working fine. I read here about unplugging the solenoid. Will that work in my case?
The blinkers...Any thoughts?
Thanks,
Steve
#3467606 - 08/28/14 03:48 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
Skid Offline
Loc: USA - Southern California
Check fuses.
#3467622 - 08/28/14 04:07 PM Re: My 98 Monte Carlo z34 [Re: Skid]
clarkflower Offline
Loc: US
I will. I was thinking more about the coolant and tranny.
Originally Posted By: Skid
Check fuses.
#3467651 - 08/28/14 04:47 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
ThirdeYe Offline
Loc: Walker, MI
We have the same shifter issue with our Grand Am. Usually if we just push the brake and the shifter button really hard we can get it to release after a while. I'd love to know if you figure it out.
99 Pontiac Firebird - 93k - Havoline 10W-30/Purolator PureOne PL10111
08 Scion tC - 119k - RP 0W-20/Purolator Classic L14477
#3467660 - 08/28/14 04:59 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
901Memphis Offline
Loc: Northern Kentucky
Yes and Yes to the transmission fluid/coolant.
The coolant i would flush and replace with something new like Zerex G05 or Motorcraft Gold after you get all the old stuff out.
Transmission fluid, i would do a pan drop/filter change and refill with Valvoline Maxlife Dex/Merc synthetic ATF.
Does the fluid have a good color to it still?
If fluid condition appears good that 1 pan drop should last 30k, but if its nasty or dark or burnt smelling rinse and repeat again in 1,000 miles with new fluid, and a 3rd time in another 1,000 miles.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3467689 - 08/28/14 05:45 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
eljefino Offline
Loc: ME
Drop pan and change fluid.
You "should" be able to get it out of park with the key in ACC, the solenoid comes on with the key fully on (running) while the anti theft cable is only with the key off and out.
Of course all this stuff can get out of whack. I'd go after that devil solenoid with whatever smashing stick you have handy. wink
#3467698 - 08/28/14 05:55 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
Trav Offline
Loc: MA, Mittelfranken.de
Steve already PM on the fluid so i will just address the shifting from park issue. Feel free to post my PM if you think someone might find it useful.
There is a small white solenoid in the steering column near the ignition switch, take the upper and lower covers off (you can weasel them without pulling the wheel) and remove this little solenoid.
Just leave the wire in there, it has an insulated connector. This cures the issue forever the only thing is you can shut it off in drive or neutral and take the key out.
It does not disable the park interlock system, once its in park. Not a real issue but be aware of it.
You can of course replace the little doodad with another short life replacement PITA.
#3467742 - 08/28/14 06:43 PM Re: My 98 Monte Carlo z34 [Re: Trav]
clarkflower Offline
Loc: US
Thanks. Just god it back with a wash. Look great.
#3467762 - 08/28/14 07:07 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
Trav Offline
You might need to do some work to the switch in the console also, can you remove the key when it does this?
#3467765 - 08/28/14 07:11 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
Merkava_4 Offline
Loc: Clovis, CA
Fluid flushes is a gimmick; just drain and refill.
Use 50% distilled water and 50% coolant. DO NOT USE TAP WATER.
#3467888 - 08/28/14 08:40 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
Kruse Offline
Loc: Kansas
Somewhere DEEP in my brain, I seem to recall that changing the alternator in a 3800-engined Monte Carlo is a royal PITA. I guess if you never have to change the alternator it shouldn't bother you. But since you have right at 110K miles on your car, I just thought I'd bring up the subject....
#3467955 - 08/28/14 10:14 PM Re: My 98 Monte Carlo z34 [Re: Kruse]
Trav Offline
Naw 20 min if that. The vans with the 3.4 are a total PITA.
#3468140 - 08/29/14 07:49 AM Re: My 98 Monte Carlo z34 [Re: Trav]
The_Eric Offline
Loc: Iowa
Originally Posted By: Trav
Vans are a total PITA.
Trav, fixed it for ya! Miserable things....
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#3468150 - 08/29/14 08:07 AM Re: My 98 Monte Carlo z34 [Re: The_Eric]
Trav Offline
thumbsup Thanks, your dead right on that!
#3468512 - 08/29/14 02:31 PM Re: My 98 Monte Carlo z34 [Re: clarkflower]
sciphi Offline
Loc: Upstate NY
One last thing: The petcocks on the radiator like to freeze into place, and then not seal once removed. I'd drain/fill through the radiator cap instead. That will get most of the coolant out of the system.
For the ATF, dropping a very long line down the dipstick tube to pump out the pan is a lot easier and less messy than dropping the pan full of ATF.
I'd consider adding a Trans-Go shift kit to help with the PCS issues that transmission is bound to have sooner or later at that mileage. For a specific ATF, Valvoline Max-Life ATF is great in those transmissions.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
Page 1 of 2 1 2 >
