[Cut Open] Champ PH2808 - Torn Pleat
by Bud_One
02/09/16 08:41 PM
2015 silverado dealer oil change
by Realtech214
02/09/16 08:27 PM
delo 400 $17/gallon at walmart now?
by motor_oil_madman
02/09/16 08:23 PM
Looks like Classics are going bye,bye at WM
by chainblu
02/09/16 08:18 PM
acdelco ph64
by gabriel9766
02/09/16 08:11 PM
Using USED oil as a top off?
by Vern_in_IL
02/09/16 07:57 PM
Question-Buying from a rental agency
by powayroger
02/09/16 07:31 PM
2010 G37xS Schaeffer's 5W30 6,800 miles, 102K
by nighamreuki
02/09/16 07:20 PM
TYC Cabin Air Filters
by DrRoughneck
02/09/16 07:19 PM
Time to vent...shop damaged wheel...again!
by gregk24
02/09/16 07:07 PM
Wooden Box Retirement Gift
by doitmyself
02/09/16 07:03 PM
PL30001 Cut open
by Dyusik
02/09/16 06:47 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
109 registered (69GTX, 04SE, 97f150, AlienBug, AandPDan, andyd, 9 invisible), 1532 Guests and 223 Spiders online.
56865 Members
66 Forums
244468 Topics
#3465207 - 08/26/14 10:22 AM subaru dash lights, engine,cruise, stability
ColonelKlink Offline
Loc: Canada
Hi, it is a 2008 Impreza. The dash lights for check engine, stability control, and cruise control all come on. sometimes even radio, wipers, and a/c do not work. it used to be intermittent. it used to be you could put the key in again, or put key in upside down, and everything would be o.k. All of a sudden, 2 weeks ago, lights all come on, and now it is no longer intermittent problem. A few years ago, I had my mechanic look over the wiring, and visually inspect, check all connections, put in di-electric grease in all the contacts he could find. We don't have a dealer in this town, so we are stuck. We are planning to make a trip to dealer in 2 weeks time. It is 2 hours away.
#3465213 - 08/26/14 10:27 AM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
OVERKILL Online   content
Loc: Ontario, Canada
Regarding the CEL + Cruise (and maybe stability?) I know that when you get a CEL, it disables the cruise and flashes the light. Perhaps they've incorporated the stability into that warning system now. The idea I believe is to draw greater attention to the CEL.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3465217 - 08/26/14 10:34 AM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
eljefino Offline
Loc: ME
Sure seems like you're losing a contact in the ignition switch.
There are two "ignition" contacts, one of which runs less-important stuff like the HVAC fan, and which is "muted" when the key is in Start to provide more power to the starter.
If you have a "body control module" it's having a fit... maybe losing communication with the engine control module which is throwing the CEL.
Scan it!
#3465234 - 08/26/14 11:07 AM Re: subaru dash lights, engine,cruise, stability [Re: eljefino]
ohforester Offline
Loc: Ohio
Couple of years ago my 2009 Forester ABS, cruise, and other lights suddenly came on. Saturday night so I could not call the dealer for a warranty repair until Monday A.M.
I searched some Subaru forums in the mean time. Found the problem:
The taillight has two filaments- 0ne for brake and one for taillight. The taillight filament burns out and drops against the brake light filament, causing the computer to think the brakes are applied, and therefore something is not right in the ABS and cruise circuits.
New bulb, fixed.
#3465289 - 08/26/14 12:11 PM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
rjundi Offline
Loc: USA
The culprit for the CEL, Cruise, and ABS means you have check engine light. That is it on Subaru. When it goes off they all go out.
It is likely not wiring problems.
The mechanic needs to read code and diagnose first.
#3465299 - 08/26/14 12:32 PM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
javacontour Offline
Loc: Illinois
Check the battery and it's connections. It's possible you have either a failing battery or bad connections.
A bad ground somewhere?
The other culprits are possible as well.
Computers and sensors like to have good power and ground.
network down, IP packets delivered via UPS -BOFH
#3466520 - 08/27/14 04:03 PM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
SteveSRT8 Offline
Loc: Sunny Florida
^^^That is an easy thing to check.
We bought a loaded Silverado in 05 that had strange electrical gremlins for almost a year. Then I checked the battery connections one day.
The positive one was loose! Just tightening that down fixed about 4 different oddities...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3466526 - 08/27/14 04:07 PM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
Nate1979 Offline
Loc: Portland, OR
Have your check engine code read at any parts store and post here. Maybe someone can help you out. The various Subaru forums are really great as well. Until you post the code it's hard to even guess at what might be the problem.
2015 GMC Sierra 2500 6.0L Factory fill
2010 Subaru Forester 2.5X QSUD 5w-30 w/ Fram Ultra
#3466570 - 08/27/14 04:50 PM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
2008wrx Offline
Loc: CA
send someone to check the brake light and of course you step on the brake.... sometimes a bad brake light switch will trigger these lights. At least mine did . pls post results
#3467075 - 08/28/14 06:06 AM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
sicko Offline
Loc: Virginia
Go to an auto parts store, most will let you borrow an ODB2 reader to pull the code from your car. Let us know what code you're getting.
#3467205 - 08/28/14 08:43 AM Re: subaru dash lights, engine,cruise, stability [Re: rjundi]
JTK Offline
Loc: Buffalo, NY
^^ This is true. On newer Soobs, when the "check engine" light is triggered, a bunch of MILs go on at the same time, given these subsystems are programmed not to work when certain CELs are triggered.
I'd mail-order myself a cheap OBDII/CAN code reader to get a read on the situation.
Edited by JTK (08/28/14 08:45 AM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#3467260 - 08/28/14 09:50 AM Re: subaru dash lights, engine,cruise, stability [Re: JTK]
Thermo1223 Offline
Loc: Easton, PA
Purchase a cheap ebay OBDII cable for the pc if you have a laptop or have a friend who does. Search for Vag-Com,
Download this then.
http://www.subaruoutback.org/forums/65-p...ur-ecm-tcu.html
Better than a standalone OBDII scanner at least for Subarus.
2004 - Jetta Wagon TDI - Gone
2009 - Subaru Forester XT - 4AT 5k OCI
2014 - Scion xD - 4AT Toyota Care
#3470633 - 09/01/14 08:50 AM Re: subaru dash lights, engine,cruise, stability [Re: ColonelKlink]
javacontour Offline
Loc: Illinois
We are all waiting to find out the results. Don't keep us hanging!
#3478842 - 09/10/14 01:14 AM Re: subaru dash lights, engine,cruise, stability [Re: javacontour]
Loc: Canada
hi, it was throwing a 420 code which could be something like overfilling the tank with fuel, or not closing the gas cap properly. another code was showing something to do with the ignition. I went to AAA and they did the reading for me for free, and suggested what it could be, and then reset the computer, so now there are no lights on at all, and everything is good. i am going to replace the spark plugs and wires, and get some other routine maintenance done like timing belt, and apparently there is an oil leak from head gasket, that needs to be replaced. thanks for all of the good pointers. actually i went to the Subaru forum, and they had a multiple page discussion about this, and how Subaru's behave or misbehave.
Edited by ColonelKlink (09/10/14 01:14 AM)
