Originally Posted By: CaspianM
Originally Posted By: y_p_w
Originally Posted By: raytseng
Top tier is a measure of cleanliness. So always get top tier as it is a certification of higher "quality" across the board (unless you add your own additives).
"Top Tier" is only one means. BP for the longest time was specifically recommended by BMW and by all accounts their additive met the Top Tier testing requirements easily. However, they didn't want to play the game (licensing fees and submitting test results) until recently. Costco's "Clean Power" (now "Kirkland Signature") additive program hasn't really changed since they got Top Tier certification. What has happened since is that they managed to get the infrastructure into all their stations and they've decided to pay the fee.
However, it seems as if most of the major marketers of fuel are paying for this program if they indeed meet the standard. There are quite a few companies that feel that too high a level of detergent additive on a regular basis is detrimental to performance (Valero for one). 76 claims they go a little bit over the requirements for Top Tier because they believe there are drawbacks.
Compliancy is a bit more than just paying for it.
How so? All the organization needs is a statement that the fuel marketer will treat the fuel that it sells with a specific additive, along with the treatment rate that it will use. I don't think they have any reason to cheat though. It's not as if it's going to cost all that much, and they've already paid for the licensing fees. Also - the fuel depots probably aren't going to let anything slip, especially with everything already programmed for specific fuel marketers.
Quote:
http://www.toptiergas.com/faqs.html
How do I become a TOP TIER (TT) gasoline marketer?
There are a few steps involved and they are outlined below. These can also be found at the website
www.toptiergas.com.
Step 1: Contact your detergent additive supplier about becoming TOP TIER.
Step 2: Obtain the TOP TIER performance testing data from your detergent additive supplier.
Step 3: Submit the TOP TIER performance testing data to the TOP TIER sponsors for review.
Step 4: Sign the TOP TIER Attestation Form which claims your exact detergent type and treat rate for use at your service stations.
Step 5: Sign a TOP TIER license agreement.
Congratulations! You are in the TOP TIER program for 1 year and can renew as desired.
