Max Life @ Menards
by scusemez28
9 minutes 35 seconds ago
Cut Super Tech ST3980 2500miles
by jhellwig
Today at 12:25 AM
Smoked my first brisket today
by MrHorspwer
Yesterday at 11:00 PM
Lowes charcoal sale
by Bandito440
Yesterday at 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
Yesterday at 10:10 PM
Need a tire
by Leo99
Yesterday at 09:58 PM
Small Engine Oil Pressure
by funflyer
Yesterday at 09:06 PM
Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
Yesterday at 08:50 PM
A/C performance woes...
by SEMI_287
Yesterday at 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
Yesterday at 08:08 PM
Microgard 51334 cut open
by dlundblad
Yesterday at 08:07 PM
Differential Fluid Selection..
by Warstud
Yesterday at 07:13 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
43 registered (bobn, Astro14, Bandito440, Black, Andy636, Abakev, 7 invisible), 732 Guests and 250 Spiders online.
58001 Members
66 Forums
249546 Topics
Page 1 of 2 1 2 >
#3466170 - 08/27/14 10:11 AM PU better than PP in 5w30?
lukejo Offline
Loc: IL
I know this has been discussed a lot, but now that PU is published with a higher Noack than PP (in 5w30), and all other published numbers look nearly identical, is there any obvious reason to go with PU other than the advertised claims of better cleaning?
((I understand both are great oils and will far surpass my requirements...am just trying to learn what I might be missing that others are seeing.))
#3466174 - 08/27/14 10:13 AM Re: PU better than PP in 5w30? [Re: lukejo]
HangFire Offline
Loc: Central Maryland
I've been scratching my head about this as well. Also IIRC Pennzoil yellow bottle 5w-20 has a lower Noack than their 5w-30. Go figure.
Various musings: http://hangfire.net
#3466179 - 08/27/14 10:18 AM Re: PU better than PP in 5w30? [Re: lukejo]
timeau Offline
Loc: Maryland
PU has higher amount of calcium (2700 vs 2300 ppm), which is a cleaning additive. So this definitely should clean better and run longer. Compare to Amsoil, where 3300+ ppm of calcium.
To be more exact, need to look on Ca+Mg combination.
2013 Toyota Camry XLE V6
2012 Honda Accord EX-L V6
#3466182 - 08/27/14 10:21 AM Re: PU better than PP in 5w30? [Re: timeau]
lukejo Offline
Loc: IL
Okay, that's good to know. Where do you find those levels? I have just been looking at their Technical Data Sheet on their site.
#3466194 - 08/27/14 10:30 AM Re: PU better than PP in 5w30? [Re: lukejo]
OneEyeJack Online   content
Loc: S California
VOA?
#3466233 - 08/27/14 11:04 AM Re: PU better than PP in 5w30? [Re: lukejo]
timeau Offline
Loc: Maryland
I think VOA section on this site is a best place to look.
#3466260 - 08/27/14 11:28 AM Re: PU better than PP in 5w30? [Re: lukejo]
Apollo14 Offline
Loc: CA
Head over to the PQIA website for comparisons.
If the cost difference is negligible or I had more cleaning needs, I would go with PU.
#3466265 - 08/27/14 11:30 AM Re: PU better than PP in 5w30? [Re: lukejo]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Base stock makeup is more important than small Ca level differences. The higher overbase will show more long drain capability but possibly MORE wear in a low saps oil if not balanced with other premium AW/EP agents/lubricants.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3466269 - 08/27/14 11:33 AM Re: PU better than PP in 5w30? [Re: lukejo]
Nate1979 Offline
Loc: Portland, OR
Better? What does that even mean? Noack is just one parameter of many.
2015 GMC Sierra 2500 6.0L Factory fill
2010 Subaru Forester 2.5X QSUD 5w-30 w/ Fram Ultra
#3466273 - 08/27/14 11:38 AM Re: PU better than PP in 5w30? [Re: Nate1979]
lukejo Offline
Loc: IL
Exactly, that was my question. As I said, I was only viewing the Tech Data on their site and Noack is the only parameter I see that is different. Obviously "better" means something, or there is no reason for a price difference. You tell me.
#3466274 - 08/27/14 11:39 AM Re: PU better than PP in 5w30? [Re: Apollo14]
lukejo Offline
Loc: IL
Thanks, will do.
#3466304 - 08/27/14 12:15 PM Re: PU better than PP in 5w30? [Re: lukejo]
Apollo14 Offline
Loc: CA
#3466306 - 08/27/14 12:22 PM Re: PU better than PP in 5w30? [Re: Apollo14]
Rand Offline
Loc: NE,Ohio
Thats not the current formulation of PU or PP.
so not very applicable.
2015 Forester I-Premium 6MT
#3466328 - 08/27/14 12:53 PM Re: PU better than PP in 5w30? [Re: lukejo]
GM4LIFE Offline
Loc: LOS ANGELES, CA
I am curious as to the real difference between Pennzoil Platinum and the Ultra Platinum.
Is the Platinum comparable to regular Mobil 1?
Is the Ultra Platinum comparable to Mobil 1 EP?
2014 Cadillac CTS-V Coupe MN6 Trans
2015i Cadillac Escalade Premium
#3466334 - 08/27/14 12:58 PM Re: PU better than PP in 5w30? [Re: lukejo]
SilverC6 Offline
Loc: Southeast
http://www.pqiamerica.com/March2013PCMO/Marchsyntheticsallfinal.html
When I see that chart, I always gravitate toward how mediocre Royal Purple 5W-30 "boutique" oil is compared to the majors and its uncanny similarity to Valvoline Synpower and NAPA's house branded Valvoline synthetic.
It's like RP just buys a truck load of Valvoline and then reformulates by adding the purple dye.
'04 Mazda RX8 5W30 Valv Synpwr
'10 &'11 Camry 5W-20 PU
'11 Landcruiser 5W20 PU
'13 BMW 550IX BMW 5W30
'08 BMW Z4M Coupe TWS 10W60
'13 BMW M6 BMW 5W30
Page 1 of 2 1 2 >
