Replacing vacuum breaker off external faucet
by Vikas
07/27/16 05:55 PM
Mobil1 EP 5W20 in Honda Accord
by alanwayne1908
07/27/16 05:46 PM
Grey color when wiping dipstick on VW VR6
by Guitarman200806
07/27/16 05:13 PM
Any audio gear junkies here?
by BeerCan
07/27/16 03:45 PM
FRAM XG7317 Cut Open After Street and HPDE Use
by HX520W
07/27/16 03:05 PM
Emergency declared on 2 California wildfires
by HTSS_TR
07/27/16 02:46 PM
Scratched interior plastic woodgrain trim
by TmanP
07/27/16 02:32 PM
Kia Sedona oil leak
by surfbum
07/27/16 02:19 PM
Castrol Australia's take on the issue with Zddp
by FordCapriDriver
07/27/16 02:09 PM
A Car Dear to my Heart - Gordon Murray F1 Designer
by HTSS_TR
07/27/16 02:08 PM
Need clarification regarding toe alignment.
by ST2008
07/27/16 02:04 PM
Engine Oil in Crusader Engines
by carverguy11
07/27/16 01:30 PM
uicgrad, snydercn, surfbum, Tmemz4, woollum86
58613 Registered Users
98 registered (alanwayne1908, 2165, 2009Edge, 97prizm, 2015_PSD, 9 invisible), 1878 Guests and 13 Spiders online.
58613 Members
66 Forums
252327 Topics
Page 1 of 2 1 2 >
#3466164 - 08/27/14 10:07 AM 15w50 and ambient temperature
19jacobob93 Offline
Loc: Gold Coast, QL, Australia
What temperature would a 15w oil start to become dangerously thick?
In another thread i told about taking the plunge from 10w30 to 15w50 to see what effects it has and to see if it fixes a few issues
My question is, would i be able to use it year round? Where i live it only gets to about freezing point a couple of times in a winter and hardly ever much below. I sometimes take roadtrips to the snow where it can get much colder
Would i need to change to 10w40 or would 15w50 still be okay?
Car: 2000 Ford Falcon AU2 - 4.0L SOHC I6 @247,000km
Oil: Valvoline Engine Armour 10W30 + LM MoS2 (7.5k OCI)
Fuel: 95 unleaded + TCW3
#3466171 - 08/27/14 10:12 AM Re: 15w50 and ambient temperature [Re: 19jacobob93]
rfeir Offline
Loc: NY
15W is too thick at startup for most applications in even just moderately cool weather. Slow to pump at startup. This can increase motor wear.
A 0W or a 5W is usually a better choice.
RPF
#3466180 - 08/27/14 10:19 AM Re: 15w50 and ambient temperature [Re: 19jacobob93]
jrustles Offline
Loc: Ontario, Canada
One has two options in this case:
a) freak out about it being too thick due to an unproportional disparity between casual imagination and reality
b) observe the CCS/MRV viscosities and borderline pumping temperature
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3466183 - 08/27/14 10:22 AM Re: 15w50 and ambient temperature [Re: rfeir]
19jacobob93 Offline
I would like to try 5 or 10w50 but they are very expensive
Im thinking maybe run the 15 through summer as it never drops below 20-25c at night (think florida type weather)
If i start to get any noises or adverse effects as we head back into winter ill probably change back to thinner
#3466184 - 08/27/14 10:24 AM Re: 15w50 and ambient temperature [Re: 19jacobob93]
19jacobob93 Offline
I'll take a sample in a couple of bottles and put one in the fridge (@4c) and one in the freezer! (@-18c)
That might give me a rough idea of winter visc, and a worse case scenario :p
#3466193 - 08/27/14 10:29 AM Re: 15w50 and ambient temperature [Re: 19jacobob93]
Quattro Pete Offline
Loc: Great Lakes
Is this for your falcon? What does the owner's manual recommend?
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3466199 - 08/27/14 10:37 AM Re: 15w50 and ambient temperature [Re: Quattro Pete]
19jacobob93 Offline
Yep!
The manual recommends 10w30 and this is also written on the filler cap but its a very old debate.
In the 1994-1998 model, the one before mine they recommended 15w40 and this had the exact same engine only with a different head gasket and altered ecu.
When the new model was introduced in 1998 they recommended 5w30 as the movement towards thin started, but quickly taxi companies were finding premature engine wear and lifter failure, so Ford issued a statement telling people to change back to 10w30 or 15w40 and this completely stopped the problem
Just seems like these engines hate thin oil, as they were a bit long in the tooth at the time being designed for 15w40 a decade earlier
Mine has always had thicker oil in but i switched to 10w30 last year because thats what it recommends, but all of a sudden all of my lifters are shot!
Cant be a coincidence so back to thick i will go frown
#3466201 - 08/27/14 10:38 AM Re: 15w50 and ambient temperature [Re: 19jacobob93]
A_Harman Offline
Loc: Michigan
15W oils get their low temperature ratings at -25C for MRV and -20C for CCS. You'll be fine at 0C, and even -10C.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3466203 - 08/27/14 10:39 AM Re: 15w50 and ambient temperature [Re: 19jacobob93]
Loc: Great Lakes
I'd find a 5w-40 oil and use that all year long.
#3466205 - 08/27/14 10:41 AM Re: 15w50 and ambient temperature [Re: 19jacobob93]
bigt61 Offline
Loc: Virginia
I've used 15W-50 M1 down to about 20F in my big block Suburban w no issues. It always flowed fast for me, I just let it warm up a few minutes before putting it in gear. It definitely flows faster than 20W-50 dino which I've seen people use year round for hundreds of thousands of miles in my area - N Virginia. If you routinely get below 20F, I'd probably use a 0W-40.
92 Suburban 2500 7.4L 58k M1_5w30 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 29k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#3466215 - 08/27/14 10:47 AM Re: 15w50 and ambient temperature [Re: bigt61]
19jacobob93 Offline
Okay that's comforting news i guess! Tried 20w50 once and it knocked like a Jehova's witness in the mornings so i dropped it straight out.
My dad used 40w70 (please don't kill him) in a mitsubishi v6 before and it ran perfect haha
Yeah won't be getting that cold very often! Maybe once every 2 years if ever so i'm excited to try 15w50 now smile
#3466218 - 08/27/14 10:50 AM Re: 15w50 and ambient temperature [Re: bigt61]
19jacobob93 Offline
Also just seen you have a 92 Suburban with a 7.4 and only 57k.
I want it.
#3466389 - 08/27/14 01:42 PM Re: 15w50 and ambient temperature [Re: 19jacobob93]
aquariuscsm Online   content
Loc: South Texas,USA
Run the 15W50 year round,you'll be fine. I started my car on a -2F degree morning (car was even sitting outside ungaraged all night) with Valvoline dino 20W50 in it,and she started right up as soon as I turned the key and purred to life. My car actually specs thicker oils and warns against using thinner oils.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#3466420 - 08/27/14 02:19 PM Re: 15w50 and ambient temperature [Re: 19jacobob93]
rfeir Offline
Loc: NY
A 0W-40 is not a thinner oil. At running temps it is a true 40. Only during cold startups is it a 0W and that is not too thin even in Florida. It pumps a lot faster which is a good thing, really. Same goes for a 5W.
Remember the W rating is not the same as the running temperature rating. A common misconception. A 0W at its rated temp is actually thicker than a 40 weight oil at its rated temperature. Different rating scales.
RPF
#3466572 - 08/27/14 04:53 PM Re: 15w50 and ambient temperature [Re: 19jacobob93]
fdcg27 Online   content
Loc: OH
According to the OM of my old BMW, a 15W-50 is fine down to
-20C, which is about -4F.
I doubt that you see that kind of cold where you live.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
Page 1 of 2 1 2 >
