UPS package tracking is so confusing!
by Klutch9
34 minutes 41 seconds ago
Dupont non-stick lube
by buck91
40 minutes 17 seconds ago
House electrical wiring question
by road_rascal
40 minutes 37 seconds ago
Air pressure question
by aquariuscsm
43 minutes 37 seconds ago
Fllow the DOT's
by WyrTwister
Today at 07:23 PM
Auto Rx?
by coopns
Today at 06:54 PM
Rotella for 6.0L Gasser
by Joefuskie
Today at 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
Today at 04:21 PM
TGMO 0W20 7700 miles UOA
by micmac
Today at 03:45 PM
"Low Coolant" light doesn't vanish.
by OpenClose
Today at 02:07 PM
Is running "Engine flush" before a change legit?
by OpenClose
Today at 01:59 PM
Who Owns A Beater?
by Red91
Today at 01:09 PM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
86 registered (ag_ghost, 06AllAmerican, 97f150, askani79705, 2015_PSD, 8 invisible), 1598 Guests and 106 Spiders online.
57738 Members
66 Forums
248227 Topics
#3466003 - 08/27/14 03:54 AM C-Clip axles and disc brakes
wirelessF Offline
Loc: Oahu, Hawaii
Checking the rear brakes on my 02 Silverado I noticed there is noticeable play on the drivers side rear axle shaft. Whenever I would make left turns I could hear the left rear brakes squeak slightly (that's why I'm checking the brakes.) I'm guessing whenever I'm making left turns the axle/brake disc pulls out and is dragging on the outer brake pad. Any way to reduce the slop in that axle?
#3466069 - 08/27/14 07:40 AM Re: C-Clip axles and disc brakes [Re: wirelessF]
Chris142 Offline
Loc: apple valley, ca
ive seen people bend the c-clip to get rid of slop.i wonder if you could machine out a shim to take up space?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3466155 - 08/27/14 09:52 AM Re: C-Clip axles and disc brakes [Re: wirelessF]
440Magnum Offline
Loc: Texas
C-clip axles don't really have any way to address it without getting clever. You could pull it apart and see if the groove in the axle is wide enough to allow a thicker clip, or a shim clip beside the current one. I've heard of the "bend the clip" trick to essentially create a wave clip, but I can't believe that doesn't still allow the same movement under hard cornering- sure, it keeps the axle in place when you tug on it by hand, but when the clip is resisting the side-loading caused by the mass of the car in a corner, its bound to flatten back out and let the axle move.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3466166 - 08/27/14 10:08 AM Re: C-Clip axles and disc brakes [Re: wirelessF]
George7941 Online   content
Loc: Toronto, Canada
When my Sierra was new the axles had no discernible play but, as the truck aged, the axles have some end play. If I jack up the rear of the truck and tug on the wheels the play is very noticeable.
2006 GMC Sierra 4.3l, NV3500,G80 locker rear, Formula Shell Synthetic 5W30, Wix 51036, Dexcool.
1987 BMW R80
Staying out of the right lane a lot.
#3466266 - 08/27/14 11:31 AM Re: C-Clip axles and disc brakes [Re: wirelessF]
Colt45ws Offline
Loc: Central Washington
How much play? You will always have some, but, if its excessive it should be addressed.
I rebuilt the traction-lok in the CVPI because axle shaft endplay was about 1/8". On that style LSD as the clutches wear the endplay increases. After rebuild the end play was .010 and .012 L/R.
-Colton
2002 Ford Crown Vic PI, 180k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#3467387 - 08/28/14 12:00 PM Re: C-Clip axles and disc brakes [Re: wirelessF]
Trav Offline
Loc: MA, Mittelfranken.de
Check for wear on the clips also. These have 0.15 wear, not much but when it has 0.35 it brings it down to 0.20.
#3467810 - 08/28/14 07:43 PM Re: C-Clip axles and disc brakes [Re: wirelessF]
dailydriver Offline
Loc: Bucks County, Pa.
This is why I ALWAYS replace the c clips with brand new ones EVERY time the axles are removed for ANY reason, even though many say it is not necessary.
It is very cheap insurance to do so. wink
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3467836 - 08/28/14 07:59 PM Re: C-Clip axles and disc brakes [Re: wirelessF]
Colt45ws Offline
That's weird. I wouldn't think they would wear at all. I mean, they just sit against the side gears; Which the axle shafts are splined to, of course. I'll have to check this out.
-Colton
Maxlife 5W20
Ultra XG2
#3467854 - 08/28/14 08:10 PM Re: C-Clip axles and disc brakes [Re: Colt45ws]
Trav Offline
The whole face doesn't wear just the small area there it touches the axle. This was after 100+K . Most of the time its just a shiny area but its worth measuring IMO when dealing with excessive play.
