This is from my 2003 Sable with the AX4N / 4F50N.
There were 16570 miles and 34 months on the Motorcraft Mercon V as of the sample date. This Mercon V was in there as part of a full cooler line exchange. However, it went in after 36,000 miles / 6 years and replaced Motorcraft Mercon V that had turned light brown.
Calcium seems low but wear levels look good. I understand that solids are the clutch pack materials so this reading is especially good?
I read that TAN above 2 indicates an ATF change is due and 3 means the ATF is worn. I have anyhow done a through the dipstick drain and fill which replaces 50% of the fluid.
Any thoughts on future intervals for 50% changes? I calculated that 50% changes every 10,000 miles equate to the recommended 30,000 mile full changes.
Code:
Iron 32
Chromium
Lead 42
Copper 93
Tin 3
Aluminium 7
Nickel 3
Silver
Titanium
Vanadium
Silicon 2
Sodium 2
Potassium
Magnesium
Calcium 49
Barium
Phosphorus 281
Zinc 9
Molybdenum
Boron 92
Water %
Viscosity (cST 100C) 6.4
Solids %
Acid Number (mgKOH/g) 1.78
Code:
Iron 32
Chromium
Lead 42
Copper 93
Tin 3
Aluminium 7
Nickel 3
Silver
Titanium
Vanadium
Silicon 2
Sodium 2
Potassium
Magnesium
Calcium 49
Barium
Phosphorus 281
Zinc 9
Molybdenum
Boron 92
Water %
Solids %
