I finished removing the TB today and started putting it back together
Removing the old TB, not sure why the lexls tutorial has you remove the belt before removing the fan bracket?
There were a couple hiccups
the fan bracket was pain to get off, mostly because it is bolted to the AC unit, and the bolts are on the side and down like a few inches below the battery.
Then there are those tiny screws holding an electrical bracket on the top of the AC unit.... had to use a 2ft long extension and socket phillips bit to get at them so that the fan bracket would be able to pull out
I changed the PS reservoir o ring, the old one was very brittle and hard like plastic, I hope that solves my leak
I zipped the cam pulleys off with an impact and went at the seals using the genius special tool...
its [censored] metal, kinda soft, which is good so that it wont scratch the shafts, I filed the back side of the paint opener using a rough metal file then used a finer grit sandpaper to get a nice flowing curve on the backside.
The RH camseal was the tightest, the LH was OK and the crankseal just popped out. The paint can opener worked great, I put the opener on top of the shafts just like when using it to open a paint can then got the sharp edge to cut into the seal as i pushed the handle down parallel to the shaft. No scratches.
I put the cam seals in using a huge socket, they went in fine.
I used a big piece of PVC to install the crankseal... until I noticed that I
pushed in the bottom too far!!... DUMB. I was ticked, luckily there was a dealer 20 mins away that had one in stock.
The one they gave me was the exact same part number but it was black, not brown like the one I got from Sewell.
Water pump reinstalled using the OEM gasket only no RTV
water inlet housing reinstalled with new orings, RTV, new thermostat and oring.
idler #1 and #2 installed.
and she is ON!
sorry i forgot the alternator pic,
waiting for my adjustable spanner to torque the cams and crank
drivebelt tensioner is squeaky, I'll prolly buy the gates one tomorrow.
