A brief BMW R1100RT story
by Finn
11 minutes 53 seconds ago
2015 6.7L Powerstroke Fuel Filter Change
by 2015_PSD
Today at 12:51 PM
Caliper question
by supton
Today at 12:48 PM
Impressed with Yokohama Geolander A/T G015
by K20FA5
Today at 12:13 PM
Need a good tire pressure guage that read over 60
by MetalSlug
Today at 11:55 AM
Castrol 0w40 vs M1 0w40 FS ?
by Ndx
Today at 11:14 AM
what old Snapper parts to save
by edwardh1
Today at 10:56 AM
Interesting lunch hour
by Urshurak776
Today at 10:10 AM
Oil and filter for 2010 Ford Taurus Limited
by MetalSlug
Today at 10:00 AM
New Hvac Install
by AirgunSavant
Today at 08:32 AM
'14 Accord - Honda 0W20 - High vis or lab error?
by vvolcano
Today at 08:18 AM
Your old ticker, take care of it
by CourierDriver
Today at 07:58 AM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
71 registered (4wheeldog, AandPDan, 97f150, 3800Series, 2015_PSD, 007, 6 invisible), 1785 Guests and 328 Spiders online.
58001 Members
66 Forums
249525 Topics
Page 2 of 2 < 1 2
#3466763 - 08/27/14 07:57 PM Re: De-glazed my rotors. [Re: eljefino]
buck91 Offline
Loc: West Michigan
I am getting some high speed (>60mph) steering wheel shudder when I hit the brakes. Last time it went away with a rotor turning, but I really don't want to burn through multiple rotors per padset on the truck...
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#3467502 - 08/28/14 02:07 PM Re: De-glazed my rotors. [Re: Rylan]
Oldmoparguy1 Offline
Loc: Charlotte, NC
Originally Posted By: Rylan
I think I've mentioned these before: for $40, they're one of the best gadgets a DIYer can buy.
Brush Research Flex-Hone for brake rotors
Amazon has several offerings for these. I'm thinking that this may be what I need to cure the brake shudder on my 13 GC. What grit do you recommend, they come in course, medium and fine.
Wayne
Experience is a hard teacher, she gives the test before the lesson.
Oscar Wilde
#3467512 - 08/28/14 02:17 PM Re: De-glazed my rotors. [Re: eljefino]
The_Nuke Offline
Loc: D/FW, Texas
PDF about Brake Judder: https://drive.google.com/file/d/0B3ISyrRQO5VlNlRqOE9HTVlfTkk/edit?usp=sharing
I don't remember where I found that doc, heck it might have even been on here somewhere, but it presents a good pretty good point about this particular subject, so I figured I should put it out for consumption.
#3467601 - 08/28/14 03:42 PM Re: De-glazed my rotors. [Re: eljefino]
Miller88 Offline
Loc: Onondaga County
I used 60 grit sand paper and a block on the Cherokee's rotors and pads recently.
After an off roading trip, I had no front brakes. They just didn't do anything.
Pulled it apart and everything was working.
Turns out there was a super, super, super fine sand that got in and glazed over the rotors and pads. Little bit of sanding and it's fine again.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3468273 - 08/29/14 10:42 AM Re: De-glazed my rotors. [Re: eljefino]
hsd Offline
Loc: NE
I have seen that washing the wheels (& car) leaves a noticeable rust film on the rotors that goes away after the next drive. I'm thinking that layer of rust should remove any pad deposits and related brake judder, but I havent fully tested this theory. Anyone with brake judder tried this?
#3468276 - 08/29/14 10:46 AM Re: De-glazed my rotors. [Re: eljefino]
Quest Offline
Loc: beaver land EH?
Regardless of the circumstances, when in doubt: it's never a bad idea to get a dial indicator and check for rotor runout before you decide on your next move (to replace rotors, deglaze it, or whatever):
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=dial%20indicator
Once you determined that the runout is within or below specs, then proceed to deglaze and slap on new pad materials, etc.
No use deglazing an otherwise warped rotor to begin with (only machining can bring them true again).
Q.
Sometimes, a significant runout (out of true) hub can attribute to rotor out of true and the perceivable results will be similar to rotor warping, even with fresh new blanks. The only way to overcome that is either to replace the hub or shim it (as what Trav has suggested before).
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3468747 - 08/29/14 07:29 PM Re: De-glazed my rotors. [Re: eljefino]
andyd Offline
Loc: Marshfield , MA
Hey, all you have to do to check for a warped rotor is to spin the wheels when they are up in the air. Check out the rotor as it goes through the pads. You will see the wobble if there is one. grin2
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
Page 2 of 2 < 1 2
