Hi guys
I just got back home from my moms house where I mowed her 3 acres with her 4 yr old Craftsman 19.5 hp riding mower.
After about an hour of mowing I noticed it would stop cutting for a few seconds and then start again
It kind of sounds like the belt is slipping but it has never done this before
I tried disengaging the blade and reengaging but this made no difference
I did notice that when I engage the blade there was not the normal tension you feel when you do this
The grass was higher than normal today if that can cause the belt to slip
I spent more time going back over spots than it usually takes to do her yard
If the belt is the issue is there any adjustment I can do or is getting a new belt the fix?
Thanks
Thanks
