Air filter was changed last oil change and oil filter is the cartridge Wix filter. It looked good. I wish all the vehicles would go to a cartridge style setup. Friends car that transports her grandkids all over the county to various functions and events when not in school.
Code:
We have a general checklist we like to see an oil report hit when we're going to recommend a longer oil run.
First, metals should be fine. Iron can be a bit higher than average on a longer oil run, but all other metals should be low
and steady. Check! The viscosity shouldn't be too far off. Check. No fuel, water, coolant, or excessive silicon should be
present. Check! Insolubles should be within limits (ideally a bit lower than the limit). Check! And the TBN should be
above 1.0. Check again! This engine hits all the required marks -- nice report! Try 10,000 miles.
OIL AMSOIL OE 0w-20 OE 0w-20
MILES IN USE 8,611 5,242
MILES 87,478 78,867
SAMPLE TAKEN 04/16/14 12/17/13
ALUMINUM 2 2
CHROMIUM 0 0
IRON 4 2
COPPER 1 1
LEAD 0 0
TIN 2 0
MOLYBDENUM 69 69
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 59 79
SILICON 16 11
SODIUM 5 3
CALCIUM 2066 2024
MAGNESIUM 23 48
PHOSPHORUS 572 680
ZINC 681 752
BARIUM 0 0
SUS Visc @210° 50.5 50.0
cSt Visc @100°c 7.43 7.26
Flashpoint In °F 425 415
Fuel %
Anitfreeze % 0.0 0.0
Water % 0.0 0.0
INSOLUBLES 0.2 0.1
TBN 2.2 2.5
TAN
Code:
MILES 87,478 78,867
ALUMINUM 2 2
CHROMIUM 0 0
IRON 4 2
COPPER 1 1
LEAD 0 0
TIN 2 0
MOLYBDENUM 69 69
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 59 79
SILICON 16 11
SODIUM 5 3
CALCIUM 2066 2024
MAGNESIUM 23 48
PHOSPHORUS 572 680
ZINC 681 752
BARIUM 0 0
Fuel %
Water % 0.0 0.0
INSOLUBLES 0.2 0.1
TBN 2.2 2.5
TAN
