Originally Posted By: ChiaroBlue
Originally Posted By: MolaKule
Cera Tec by
LiquiMoly is Boron Nitride in an oil carrier.
Boron type components are already included in most motor oils.
LiquiMoly Oil Additive by
LiquiMoly is a suspension of SOLID MoS2 powders in an oil carrier.
Better moly chemistries are already included in most motor oil PI additive packages.
This is my first post on BITOG, so bare with me. First, as disclaimer let me state that I have tried Liqui Moly Cera Tec both in my 2006 diesel (MB 320 CDI) and also in the engine and synchronised manual gearbox of my V12 engined gasoline car. In both cars I notice greatly reduced engine braking after the addition of Ceratec and very smooth shifting in my manual car with Ceratec in the gear box. In the manual gasoline car, reduced engine braking is very nice as the car is no longer so "jumpy" when driving slowly in first or second gear. After the addition of Ceratec, the following specific problem disappeared: When standing still, I occasionally could not shift into first gear and had to shift into second and then into first. With some 7 per cent Ceratec in the gearbox this problem does not occur anymore.
What made me confident enough to try Cera Tec was the fact the Liqui Moly recommends the addition of Ceratec to their own manufacturer (VW 507.00 etc) approved oils (for example here:
http://forums.thecarlounge.com/showthread.php?5816920-Liqui-Moly-Oil-Forum). Also, the German version of Amazon (Amazon.de) has many positive customer reviews of Ceratec (with many of the reviewers commenting on reduced engine braking, quieter running engine etc). In addition, a test report on Cera Tec from TÜV Thüringen Anlagentechnik GmbH can be found (8141.102.04.40 – 174113). I also contacted Liqui Moly to make sure that Ceratec really can be used in synchronised gear boxes (contrary to what I had read on BITOG).
This is the reply I received from Liqui Moly concerning the usage of Cera Tec in synchronized gear boxes (Yes!) and limited slip differentials (No!):
___________
Dear Sir,
thank very much for your mail and for your interest in Liqui Moly products.
Your questions:
Is LM ceratec usable in:
1) a synchronised gear box (GL-5 80w-90 gear oil recommended
=> Yes, in synchronised gear boxes and diffs without self-locking, it is optimal to add CERA TEC in the same best dosage as in engines from 7 till max. 8% to theoil!
2) self-locking rear and front differential (gl5 85w-90 recommended), or is this considered a "wet clutch"?
=> Do not use CERA TEC in self locking diffs in which is a wet clutch oil in use. Becaus in thouse case you will change the necessary friction for the wet clutch and than there will be no right diff locking!
If you have any more question, contact us again!
___________
Now, I understand that Boron type components are already included in most motor oils – but to my understanding the hexagonal form of boron nitride (a solid lubricant) is not usually included, correct? Can we really dismiss hexagonal boron nitride just because boron type components are included in oils? What do we know about the efficiency of hexagonal boron nitride as a friction modifier? What do we know (scientifically) about the negative effects, if any?
Could anyone comment on the following paper on the Tribological effects of bn and mos2 nanoparticles added to polyalphaolefin oil in piston skirt/cylinder liner tests:
http://www.transportation.anl.gov/pdfs/MM/857.PDF
Or on this patent for a transmission oil containing hexagonal boron nitride:
http://www.google.com/patents/US20080280793
Interestingly, the first paper states that: “The dispersion of nano-sized materials in oils is an emerging concept in lubrication. Nanomaterial additives may help counteract friction and save energy”.
Isn't engine braking mostly attributed to seal and compression(ability) vs. Friction?
As this would lead me to think the seal gets compromised by Cera tec...
