The adbv does more than just hold oil in the filter, it also holds oil in the oil galleries leading to the filter also helping prevent or reduce a dry start condition. So even filters with a thread end up orientation can require an adbv.
And as some GM applications with thread end application show, having an adbv will never cause any harm even where not spec'd. The reverse is not true. This is why some aftermarket manufacturers and even AC Delco it appears, just use an adbv to cover all applications whether originally spec'd for an adbv or not. A more recent thread/post linked below explains such an example.
http://www.bobistheoilguy.com/forums/ubb..._mi#Post3141456
