We strengthened the internals with 4032 Al allow forged pistons (head studs, STi rods, etc) and improved the oiling system and the builder is now recommending 5W-40 oil following break in.
However, the break in process is elaborate with:
1. 20 min oil change - warm for 10 min, run at 2000 rpm for 5,
2. 100 km oil change - intentionally vary the rpms constantly in this first drive, but do not to exceed 5500 rpm, and
3. 1000 km oil change - avoid constant rpm running.
Happy to follow the break in process as recommended, but have you any insight into the purpose of a recommended break in like this?
Here's some tech trivia on forged piston alloys:
EngineLabs TECH5: Trey McFarland of Mahle Motorsports Reveals Piston Secrets
Built EJ205
Build Specs
Built EJ205
Build Specs
