I think you will be fine. Are you confident the bump stop will prevent it from occuring again? If so you are all set, otherwise id consider rolling your fenders..i have run into the same issue my back tires scraped the sidewall like yours..it shredded the tire like yours..just not as deep but still when i load up the trunk or go camping it happens. I was thinking of rolling the fenders..but havent yet. Im running 225 45 17..oe is 185 65 15. Hoping your bumpstops fix it. Im actually wondering if that might be a low cost solution for me without having to roll the fenders..as id rather not roll them. Im running stock suspension so im not even that low..
