Ok, I purchased our 2005 Nissan Xterra at 60,000 miles. I know I should have drain/filled the transmission at that time, but I didn’t. The truck now has 86,000 miles, and is now mine as the wife just bought a new car. I have done the transmission bypass (as these are known for the radiator leaking and ruining the transmission) and purchased a 2nd cooler. To check for any possible coolant in the fluid, I sent a sample to Blackstone and got this back:
Now my main question is, am I ok to do a drain/refill at this point without hurting anything? I know the mileage is getting up there, and I would drain/refill every 8,000 miles or so until I feel the fluid has been relatively flushed. Also considering pulling the pan, checking the magnets, and cleaning the “screen”. I would also replace with Matic J if I can find local, if not, I will just put Matic S in.
Thanks
Thanks
