Originally Posted By: BobsArmory
I have no real Idea what is in Restore but I am sure Ceratec isn't gear oil.
Liqui Moly (the makers of Ceratec) is a respectable German oil company that actually make products that work.
Cera Tec
Cera Tec is a high-tech ceramic wear protection and can be mixed with all commercially available oils. Cera Tec reduces friction and wear by using chemically and thermally extremely high-resilient ceramic compounds. Prevents direct metal/metal contact, increasing the service life of the aggregate. The smooth-running effect reduces fuel consumption in petrol and diesel engines.
EP gear oils perform well over a range of temperatures, speeds and gear sizes to help prevent damage to the gears during starting and stopping of the engine. Unlike AW additives, EP additives are rarely used in motor oils. The sulfur or chlorine compounds contained in them can react with water and combustion byproducts, forming acids that facilitate corrosion of the engine parts and bearings.[1]
EP additives typically contain organic sulfur, phosphorus or chlorine compounds, including sulfur-phosphorus and sulfur-phosphorus-boron compounds, which chemically react with the metal surface under high pressure conditions. Under such conditions, small irregularities on the sliding surfaces cause localized flashes of high temperature (300-1000 °C), without significant increase of the average surface temperature. The chemical reaction between the additives and the surface is confined to this area.
Molybdenum compounds decompose under high pressure to form an in-situ deposited layer of molybdenum disulfide. Molybdenum dithiocarbamates are used as additives for greases.
