What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Grease that's universal on ALL aspects of car care
by NattyBoh
07/24/16 09:45 AM
Oil made from natural gas?
by Sealbilly
07/24/16 09:18 AM
Rotella line upgraded
by Sealbilly
07/24/16 09:13 AM
Kendall VersaTrans LV for Toyota WS?
by Slick17601
07/24/16 08:03 AM
Clutch problem
by chrisri
07/24/16 07:49 AM
Peppers: do you grow them?
by car51
07/24/16 07:29 AM
Havoline conventional $2.99 at Rural King
by car51
07/24/16 06:35 AM
killing weeds without poisoning well
by oilboy123
07/24/16 01:27 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
83 registered (4WD, andyd, Al, AandPDan, alanwayne1908, aquariuscsm, 7 invisible), 2025 Guests and 14 Spiders online.
58578 Members
66 Forums
252186 Topics
Page 1 of 5 1 2 3 4 5 >
#3460905 - 08/21/14 01:27 AM DI intake valves CAN be cleaned with PEA?
Alext Offline
Loc: SA
According to this article "A vehicle that had run for 20,100 km in Example 4 was reassembled with deposits intact. The vehicle run for an additional 1,100 km using the same fuel described in Example 4 but with the addition of the polyetheramine (PEA) from Example 5 at an order of magnitude increased treatment level; that is, an aftermarket treatment level. The concentration of PEA in the treated fuel was 21 ppm by weight of nitrogen and was 3200 ppm by weight on an actives basis. It was also found that intake valve deposits, which are not directly impacted by additive in DISE engines under normal dosages/operating modes, were reduced by 23% by this treatment."
Found it here: http://www.google.com/patents/WO2003078553A2?cl=en
They mention that usually in DI engines valve deposits are not affected by fuel additives but in their test they showed that at higher concentrations it can reduce the deposits. I wonder what concentration of something like Redline SI-1 that translates to?
#3460913 - 08/21/14 01:58 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
OneEyeJack Offline
Loc: S California
There are some diesel engines here with DI that are in generator service with instructions to use a PEA additive in the fuel. They function as back up power and generally run about 20 hours a month. A service bulletin a few years ago advised doubling the original dose because of valve deposits.
#3460915 - 08/21/14 02:22 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
wemay Offline
Loc: South Florida
Maybe why Hyundai recommends Thechron (in Hyundai packaging) every service visit or 5k miles and top tier fuel.
16 Toyota Corolla LE 1.8
TGMO 0W20 | OEM | 10K
13 Hyundai Santa Fe 2.0T
VWB/VSP mix 5W30 | VO106 | 3K
#3460923 - 08/21/14 03:13 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
wemay Offline
Loc: South Florida
http://crcindustries.com/auto/intake-valve-cleaner.php
Another product specifically marketed towards GDi applications.
#3460976 - 08/21/14 06:39 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
sicko Offline
Loc: Virginia
Interesting results. I don't have time to read the full article right now, but I'll check it out later.
#3461010 - 08/21/14 07:31 AM Re: DI intake valves CAN be cleaned with PEA? [Re: wemay]
knerml Offline
Loc: NE Ohio
Hyundia/Kia is pushing Techron for all of their cars, not just ones with DI.
2011 Kia Sorento 2.4 Mobil1 5W20 & OEM Filter
2015 Hyundai Elantra Sport 2.0 GDI Mobil1 5W20 & OEM Filter
#3461041 - 08/21/14 08:08 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
badtlc Offline
Loc: KC
I have been overdoing it by using Gumout AIO in one tank (12 gallons) when it is recommended for up to 35 gallons. I'm thinking that might not be so bad of an idea now. I got a bit worried when the Gumout Q&A said 18gal minimum for the AIO product.
2007 Ford Escape XLS 2.3L ATX, Trop Artic 5W30, Fram OCOD, 140k+
2015 Chrysler T&C, 45k+
#3461085 - 08/21/14 09:17 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
demarpaint Offline
Loc: NY
How does the product get to the back of the intake valves to clean them?
God Bless Our Troops
#3461118 - 08/21/14 09:46 AM Re: DI intake valves CAN be cleaned with PEA? [Re: demarpaint]
Rand Offline
Loc: NE,Ohio
Valve timing. IIRC ford does this.
Others like audi Did not at least on first gen DI and they had massive issues with it.
Edited by Rand (08/21/14 09:47 AM)
2015 Forester I-Premium 6MT
#3461123 - 08/21/14 09:50 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Rand]
demarpaint Offline
Loc: NY
Thanks. So if you have an early generation DI engine it isn't going to work?
#3461131 - 08/21/14 09:56 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Rand]
crw Offline
Loc: Pocatello, ID
Huh? OK, are we saying that the fuel and cleaner mixture gets pushed out of the cylinder into the valve chamber in sufficient quantity to clean the valves?
2005 Nissan Maxima, 6-speed manual; many others...
#3461135 - 08/21/14 10:03 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
Vikas Offline
Loc: NorthEast
A question to resident GDI experts; since the fuel is injected on the intake stroke, why does the fuel needs to be at 2000 psi? Isn't there is a negative pressure (aka vacuum) in the cylinder during the intake stroke?
Another question:- CRC generally don't make snake oil type products but is it really possible to melt the carbon deposit on the back of the valve by spraying a strong solution? Why doesn't they conduct an experiment to show cleaning off the carbon-ed up valve on camera?
#3461139 - 08/21/14 10:06 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
MCompact Offline
Loc: KY
I run a 20 oz. bottle of Techron through my Mazda every 3k miles and only use Top Tier fuel. So far it appears to have kept me from needing to clean/replace the EGR valve for a second time...
Mine:
2014 M235i
1999 Wrangler Sahara
1995 318ti Club Sport
1996 Speed Triple
Wife's:
2004 X3 2.5i
Son's
2009 328i
Buy what makes you smile...
#3461147 - 08/21/14 10:13 AM Re: DI intake valves CAN be cleaned with PEA? [Re: crw]
demarpaint Offline
Loc: NY
That's why I asked. From what I've gathered here and from talking with experts there aren't any in tank cleaners that will work, unless something has changed with the rolling out of the 2015's that I'm not aware of.
#3461162 - 08/21/14 10:35 AM Re: DI intake valves CAN be cleaned with PEA? [Re: Alext]
crw Offline
Loc: Pocatello, ID
It's amazing how many people still don't understand the issue of direct injection vs. legacy fuel injection and the cleaning of valves.
