New kitty training:
by Eddie
8 minutes 52 seconds ago
How to build credit with a credit card
by Nick1994
Today at 03:00 PM
Need Coolant Advice for 2000 Suzuki Motorcycle
by ZeeOSix
Today at 02:32 PM
bigger longer of FL820s
by MetalSlug
Today at 02:24 PM
I got a new to me 2011 Impala, advice?
by gfh77665
Today at 02:15 PM
Guy drinks STP OIL TREATMENT
by FordCapriDriver
Today at 02:09 PM
2006 Hyundai Tucson - plastic in the pan
by OVERKILL
Today at 01:54 PM
AC = bad
by gman2304
Today at 01:51 PM
Refrigerator top light not working
by PandaBear
Today at 01:47 PM
EGR and braking
by otis24
Today at 01:45 PM
Replaced 109S with 114T; pressure recommendations
by George Bynum
Today at 01:40 PM
Old oil for edger oil change
by brian_06328
Today at 01:18 PM
SonofJoe, Axle_Needle, discobob, KHump, Zounds
58573 Registered Users
71 registered (4WD, 41 Plymouth, Anduril, AIRJAC3, andyd, AndyB, 10 invisible), 1787 Guests and 10 Spiders online.
58573 Members
66 Forums
252156 Topics
Page 3 of 3 < 1 2 3
#3441190 - 07/30/14 10:49 PM Re: Undercarriage protection [Re: cookiemonster]
Mr_Accord Offline
Loc: LBP
+1 for Krown or even Rust Cure Formula 3000
1990 VW Jetta GL 1.8L 8V - SOLD
1992 Honda Accord Lx - SOLD frown
1993 Ford Aerostar XL 4L V6 - Retired RIP
2004 SAAB 9-3 ARC 2.0T - Current
#3460673 - 08/20/14 07:53 PM Re: Undercarriage protection [Re: jcwit]
FXjohn Offline
Loc: NE Indiana
Originally Posted By: jcwit
I've been using RustCheck for the last 6 years.
http://www.rustcheck.com/
Worked great on my '01 Ford Escort till it dropped a valve seat. I'm in the northern part of Indiana where salt is a daily issue in the winter.
A DIY option is spray cans of Fluid Film.
http://www.fluid-film.com/company.html
usually available at John Deere dealers.
If you can go into Canada, look for Krown.
Hey JC who applies your rustcheck?
#3460727 - 08/20/14 08:40 PM Re: Undercarriage protection [Re: cookiemonster]
doitmyself Offline
Loc: MI
I communicated with JC 3 years ago and I believe he uses the South Bend store with good results.
To slow down existing rust in my old Caravan 3 years ago, I tried Werner's in Fort Wayne. They seemed like an awesome shop, but when my rocker panels broke through from rust, they seemed to be dry inside....no rust control oil in there.
I think the treatment helped slow down pre existing rust in the door bottoms.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#3460773 - 08/20/14 09:21 PM Re: Undercarriage protection [Re: demarpaint]
JHZR2 Offline
Loc: New Jersey
Originally Posted By: Turk
How about Amsoil Heavy Duty Metal Protector (HDMP)??
It is working well for me.
Unfortunately it didnt work well for me in my tests. I sprayed it at various underhood points in my saab 9-3, as various fasteners were developing surface rust. Some of the fasteners were showing rust, others were pristine. In both situations, I saw some delamination of the HDMP against the fasteners and the metal surfaces around them. The ones that were rusty previously showed further rust, indicating that protection may still allow some diffusion of moisture.
IMO, these coatings should only be used with an oil/lanolin coat over top of them, unless being used on an enclosed space where there is no risk of the HDMP type hard wax coating being damaged.
Heat also seems to be a factor, as my test was underhood.
#3460817 - 08/20/14 09:49 PM Re: Undercarriage protection [Re: JHZR2]
demarpaint Offline
Loc: NY
I remember you mentioning that once before in a thread. I won't be using it any more. I decided I will be using a Cortec product next new vehicle, and I will treat my Liberty with that as well.
God Bless Our Troops
#3460820 - 08/20/14 09:52 PM Re: Undercarriage protection [Re: cookiemonster]
JHZR2 Offline
Loc: New Jersey
Yeah it's a bummer because the HDMP and similar products from Eastwood, waxoyl, etc have promise and some are easier to get.
What are the details on this new product you'll be using? Would love to hear about your technique and approach, given your background.
#3460825 - 08/20/14 10:07 PM Re: Undercarriage protection [Re: cookiemonster]
demarpaint Offline
Loc: NY
Here are the specs on the product.
Cortec VpCI-368 leaves a firm, wax-like film that can be removed by mineral spirits or alkaline cleaners . Typical applications include pipe coating, parts storage, underbody coating, wire rope, steel plate and machined parts. It protects carbon steel, stainless steel, copper, aluminum and cast iron. VpCI-368 may be applied by brushing or spraying. A film thickness of at least 2-3 mils is recommended for uncovered outdoor storage. Available in 5 gallon steel pails (Cortec Product Code 12300038) or 55 gallon metal drums (Cortec Product Code 12300039). 5 gallon drum weighs 50 pounds and ships under our standard shipping rates. The 55 gallon drum must be shipped by truck. We will provide you with a freight quote before we ship this product.
Features:
Flexible
Excellent salt spray protection
Excellent outdoor protection
Multimetal protection
Excellent UV resistance
Moisture displacing
Cured film is heat stable up to 392 degrees F (200 degrees C)
Conforms to MIL-PRF-16173E (Grades 1 and 2)
NATO 6850-66-132-5848
NATO 6850-66-132-6099
NSN 8030-00-062-6950
NSN 8030-00-231-2345
NSN 8030-00-244-1300
NSN 8030-01-470-2601
Trav has used it before with excellent results, it is not cheap. I've used similar products years ago, I got a little lazy with my Jeep and went with spray bombs of the HD Metal Protector. I have zero rust and think this product will be just fine over the Amsoil product.
I plan on spray applying it, with a conventional sprayer and a good rustproofing/undercoating gun using existing openings and access points. Two coats with one week dry time between coats, then annual inspections and touch ups. IIRC this product is used for aviation as well as marine use and should hold up quite well. I want a coating I can see through, and this fits the bill nicely.
I'll buy 5 gallons of it, and either sell some off to my brother, a friend, or use it up myself.
Edit: I have one of these to apply it with:
Professional Undercoating Gun
Item #19867 Brand: Eastwood
Edited by demarpaint (08/20/14 10:12 PM)
#3460861 - 08/20/14 11:15 PM Re: Undercarriage protection [Re: doitmyself]
FXjohn Offline
Loc: NE Indiana
werner's missed a spot inside a crossmember on my truck. I was thinking of trying to use a shop in syracuse that uses corrosion free, which is supposed to be better anyway. what was the shop in south bend?
#3460872 - 08/20/14 11:31 PM Re: Undercarriage protection [Re: cookiemonster]
jcwit Offline
Loc: no. indiana
Off hand I don't remember,google RRustCheck and do a location search.
I drove to Ohio and had Krown put on 2 weeks ago, it was Gus's Auto in Versails, oh.
#3488277 - 09/20/14 09:01 AM Re: Undercarriage protection [Re: jcwit]
FXjohn Offline
Loc: NE Indiana
I was thinking of using them too, but I may give the corrosion free a try. I ordered some spray cans so I could see it, and it's pretty benign stuff. clear and a mineral oils smell
Page 3 of 3 < 1 2 3
