Originally Posted By: DemoFly
The 2011 E350 cutaway and our 2012 5.0L F150 in my work fleet keep [censored] out on us. Albeit small things: a coil, a window washer fluid pump, a transmission sensor seal, brake rotors needing turned every 8k miles, ECU reprogramming to get the transmission to shift correctly.
And my co-worker, who bought a 2003 V8 Explorer constantly talks about the work he has to do on his vehicle.
Yet he always blindly states, "Can't be a Ford for work."
Our Toyota Tacomas and Tundras are brilliant. Our 4.7L ram is great. Our 1999 6.0L 2500 Silverado is arguably the best truck ever made. They have only needed regular scheduled services. The Toyotas are so great we are only buying Toyotas from now on.
Why are Fords considered the best for work by so many people?
Why is a thread about brand loyalty turning into a Ford bashing thread? I don't know.
I consider certain Ford models ideal for my needs because they consistently work without issues and without drama. I have owned two Rangers and a Ranger based 2-door Explorer. None has ever left me stranded. None ever hit me with a $1K repair bill. None has ever really been that aggravating. I have never had one fail to start, ever. Literally every single time I have turned the key in one of my Ford trucks, they have started and took me where I needed to go. I can't say the same for some other brands. Why would I not keep buying and driving Rangers?
My current one has been the best. It has been in a severe wreck...if it was an insurance job, this truck would have been salvaged out four years ago. It has thousands upon thousands of miles of towing under its belt. No issues there. I can still punch it, make it shift at 5500 RPM, and it's fine...in fact, that's when it runs best.
The best part...no blend doors knocking away behind the dash, no EVAP clusterf*k, no plastic bed, no sludge, no sagging doors, no broken door/tailgate handles, all features work, A/C is super cold within a minute or two, etc. Worst fit & finish issue on this truck is the driver floormat developed a hole after about 10 years, and the driver's seat belt buckle was somehow installed backwards. At idle this wrecked, 12 year old, 155K mile Ford truck sounds like a Lexus...in that you can barely hear it running. There are still times I have to look at the tach to make sure it's running so I don't turn the key over again.
So maybe that explains my brand model loyalty. Certain vehicles I love, because they work for me. I like them. As far as the manufacturer, I could hardly give a [censored]. There are plenty of Fords that I would refuse to buy even on the coldest day in [censored]. With others though, I keep buying them because they work and I like driving them.
Wholesale brand bashing is every bit as dumb, if not dumber, than brand loyalty.
