Originally Posted By: Fleetmon
Thanks for the link. Yes, I know it's fairly cheaply made but it appears it will serve our purpose. As long as parts are available I can keep them going.
I had already planned on using Rotella Triple-T 15w40 in them.
Yeah I forgot to mention, that with keeping the fuel treated ours starts on the first pull (within reason) every time and runs great, we have had the one for several years and bought it used, it still runs like new.
I have had to put a tube in the rear tire, replace the chain, carb (PO had it messed up), kick stand spring. My only real complaint is the brakes suck and need constant adjustment, but they do make a hydraulic kit for them....
I did one mod, I fabricated an adapter so I could put a "cone" air filter on. I used a common racing go-kart air filter and it improved throttle response and just seemed to smooth the whole power band out a little bit.
