Originally Posted By: Shannow
If somehow the hydrocarbon oil replaced gasoline, and escaped combustion entirely...the premise that oil leans you out and melts pistons is farcical.
Well, how is it making the exhaust damp on your OPE then? Some oil must escape combustion. Try running 20:1 for a tank, you will see that more oil ends up on your exhaust. I doubt you'll melt a piston unless your motor is running quite lean at 50:1, but in some cases, 2-3% less gas by volume may make a difference.
