Hello All,
I am looking into doing some DIY tire changing.. I was curious.. with the proper tire lube, and other tools, Is it possible to get a tire beat to set with a normal Road side emergency air pump? One that doesn't have any kind of tank just slowly fills, Or will I definitely need some kind of higher flow Air compressor? I am not interested in setting tire beads with starting fluid, because it just seems dangerous.
I guess if my home air compressor wasn't enough, I could load the tires into the trunk of my (other)car and go to a gas station.
Thanks all!
Thanks all!
