Originally Posted By: G.Frost
With only 80K miles, I can't imagine the engine has much wear. It is barely broken in.
Perhaps I should give some background.
The truck was bought new by a man that had (as it turned out) terminal cancer, he put about 30k on the truck before he died. His widow did not want to sell "His" truck, so it was parked in the Basement garage for 20+ years.
Eventually the widow was put in a home (she had dementia)
and the Granddaughter found the truck when she was clearing out the home.
It was then towed to a Les Schwab dealer to be brought into running condition.
That's when I bought it.
It was running a little rough at Idle, lacked off Idle torque and burned a little oil (you could see a slight Blue haze at the tailpipe) Compression was 225 psi and even.
I suspected a stuck piston ring and gave it two full Arx treatments as per the instructions Du Jour
(this was all the rage 6 years ago) but it was to no effect.
I continued short 3k oci's for the next two years, then one winter used 1/2 litre of MMO for the last 1k of my OCI. Suddenly, the idle became smooth and the oil consumption has been negligible since for the last 3 years.
OCI's have been at about 4k and I have used PYB, QS and on two occasions Maxlife (whatever is on sale) and not had any problems.
I first noticed these strange 'Puffs' of Blue about 2 weeks ago. I have not noticed a measurable loss of oil in that time. But as I have said, when it does happen it is noticeable and has caused (friendly) comment from other people.
