Lowering vehicle with alternative coil springs
by OlDirty
25 minutes 30 seconds ago
Remington R1 1911 or Springfield 1911-A1 MIL-SPEC
by MuzzleFlash40
45 minutes 58 seconds ago
2017 Ford F150 3.5 EcoBoost
by DuckRyder
Today at 05:25 AM
Ford Powershift Gearbox Class Action (Oz)
by hpb
Today at 03:50 AM
Central Mississippi automotive goods
by mjoekingz28
Today at 02:11 AM
Free: 5 Quart jug Peak 5W-30
by Indyvwhonda
Today at 01:01 AM
Subaru Oil Burning Class Action
by Bandito440
Yesterday at 11:43 PM
'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
Yesterday at 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
Yesterday at 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
Yesterday at 10:38 PM
Briggs and stratton flathead?
by pdxglocker9mm
Yesterday at 10:27 PM
Charcoal
by dlundblad
Yesterday at 09:43 PM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
70 registered (2015_PSD, AirgunSavant, A_Harman, bbhero, 2002 Maxima SE, beanoil, 11 invisible), 896 Guests and 297 Spiders online.
57790 Members
66 Forums
248441 Topics
Page 3 of 3 < 1 2 3
#3455720 - 08/14/14 07:07 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Jarlaxle Offline
Loc: New England
Again, my Caddy has over 100K on its catalysts...passed its last emission test (also IM-240) last year, about 10% the allowable emissions. High-flow cats I think are Magnaflow.
1979 Coupe de Ville, 542 stroker, 15W-40 Super Tech, Delco
2011 Crown Vic P71, 5W-20 Valvoline NextGen, Purolator
2012 Suzuki AN400A, 10W-40 ST, Delco
#3465620 - 08/26/14 06:03 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
InvalidUserID Offline
Loc: Bay Area, CA
UPDATE: Replaced EGR, numbers improved quite a bit at 15 mph but not enough at 25 mph. The car was run about 20 minutes prior, 10 minutes on the highway or so (more on temps later). Here are the numbers on this rescan.
The smog shop suggested I come back in the morning when it's a bit cooler (it was 76f at the time). The smog technician said it looked it was going to pass and then the computer kicked him out and then he had to test again, the second time it didn't look good.
Took it to my mechanic right after and he suggested the same. He was surprised when I told him the shop didn't have the big shop fan on the car during the test, said they are supposed to do so. He asked how long the car was being tested and I said it was on the dyno machine for about 15-20 minutes and idling in between runs. He said the EGR passages were good when he replaced the EGR valve.
Would going in the morning be enough and if not, do I need to look at the cooling system or simply replace the 20k mile cat?
Edited by InvalidUserID (08/26/14 06:04 PM)
My Cars aka old reliables:
- '96 Camaro 3800 II
- '97 4.0 Grand Cherokee
- '99 Civic EX
#3466388 - 08/27/14 01:42 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Loc: Bay Area, CA
Co-worker of mine asked how the smog went. When I told him about the lack of fan during the smog runs, he thinks that might have had an adverse effect on the numbers as well.
Cooler morning and making sure shop points the fan at the car, numbers improve?
- '99 Civic EX
#3466407 - 08/27/14 01:57 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Skid Offline
Loc: USA - Southern California
My guess is that your catalyst is fine because the CO and HC levels are OK. I think the head is running hot.
Did you check your cooling system? I'd suggest changing the thermostat and doing some pressure testing (and changing the radiator cap too). Also check the concentration of coolant - too much coolant, too little water will make the head run hotter. Might help to have the heater running during the test as well, but won't hurt at least.
Also, you wrote earlier that "Cooling system just drained/refilled." Perhaps it wasn't fully burped initially and the higher earlier NOx readings were due to that.
#3466427 - 08/27/14 02:35 PM Re: Failed CA emission - high NO [Re: Skid]
Bladecutter Offline
Loc: Dacono, CO
Here's all of the OP's smog tests in one shot:
First one from this thread:
And now this one after replacing the EGR:
I find it off that his NOx emissions are so much higher at lower rpms.
The car must be shifting into a lower gear, and then the tester is taking the reading under load to get the NOX scores to increase, yet all the other emissions get reduced under the same conditions.
I still think it's the convertor, since the readings for NOx are all higher after the years, but OP, try dumping a bottle of Techron Fuel system cleaner into your tank, and run through the whole thing as quickly as you can, to remove any combustion chamber deposits that are increasing NOx readings while under load.
Also, when was the last time plugs and wires were changed?
I know with my old '92 Park Avenue, if I didn't change the wires every year, one wire would start shorting to ground under load, and cause a slight miss. That doesn't seem to be the case with your HC readings, but something is causing the NOx to raise up.
BC.
2014 Mazda CX-5 Touring (Soul Red)
2015 Porsche Cayman
2007 Ducati 848
1988 Honda Hawk GT
#3466467 - 08/27/14 03:24 PM Re: Failed CA emission - high NO [Re: Bladecutter]
Skid Offline
Checking the cooling system is much cheaper than changing a catalyst. But it's not my money.
#3466480 - 08/27/14 03:40 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Loc: Bay Area, CA
Thanks for sharing your opinions guys.
Plug wires are relatively new, about 20k on them. Not sure I have enough time to add a cleaner and burn the tank as the sticker expires this weekend. I paid but due to smog fail, it's an incomplete registration. Not sure if I can still get a ticket, don't want to find out.
Re-checked on the coolant: It was flushed and replaced 20k ago but that was about four years ago. Not sure how I overlooked the date in my paperwork. Given how it's four years old, DexCool and that I have/had a very slight timing cover leak, I will get it flushed out and refilled tomorrow at a radiator shop that's fortunately for me, right near a client I'll be at for a few hours.
I have noticed coolant temp gauge taking longer to drop after idling. Not sure if that's related to the NOx and if it is, hopefully a flush and fresh fluid/thermostat takes care of it.
Edited by InvalidUserID (08/27/14 03:42 PM)
- '99 Civic EX
#3466498 - 08/27/14 03:52 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Skid Offline
Originally Posted By: InvalidUserID
I have/had a very slight timing cover leak...
That would be enough, hence the earlier pressure testing recommendations. My guess - your system is low on pressure because of this leak, and the coolant is boiling at some points in the head (it's like not having a radiator cap). Fix the leak and you'll probably pass.
#3466708 - 08/27/14 06:59 PM Re: Failed CA emission - high NO [Re: Skid]
Loc: Bay Area, CA
Didn't think a small leak would have such impact. I noticed a small amount of coolant on my garage floor and took it to my mechanic. He pressure tested it, said timing cover had a small leak. Tried some stop-leak to see if it would work. Not that he didn't want to do the repair or take my money (he didn't charge anything) but wanted to see if the easy fix would work for such a small leak.
Any idea how big of a task that timing cover would be? Want to see if the shop can take care of it and a flush in one shot.
- '99 Civic EX
#3468067 - 08/29/14 03:14 AM Re: Failed CA emission - high NO [Re: InvalidUserID]
mehullica Offline
Loc: Modesto,CA
You have a higher than normal level of O2 on your readings. A vacuum leak or lean mixture will raise the O2 levels. Your HC & CO are decent which means you're not having a catalytic converter issue. I think your engine has a small vacuum leak causing a run too hot & fail for NOx. Can you check your O2 readings with a scantool or the obd port with a voltmeter?
#3468264 - 08/29/14 10:20 AM Re: Failed CA emission - high NO [Re: mehullica]
Loc: Bay Area, CA
Yes, I have an OBD II scanner. What data should I look at?
- '99 Civic EX
#3468673 - 08/29/14 05:46 PM Re: Failed CA emission - high NO [Re: mehullica]
paulo57509 Offline
Loc: Tracy, CA
I think '96 Camaros have an air pump (electric) that introduces additional air into the catalytic converter. If an air pump is present, there will always be excess O2 present.
1987 Chevrolet Camaro IROC-Z 5.0L
1987 Acura Legend L Coupe 2.7L (5-Speed)
1992 Lumina Euro Coupe 3.1L
1998 Lexus LS400
2003 GMC Safari
#3470048 - 08/31/14 12:23 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
mehullica Offline
Loc: Modesto,CA
Look at your o2 voltages at 2500 rpm on a hot engine. Look at the voltage changes to see if they are switching above & below .5 volts at least a few times a minute. Then let it idle & watch the voltages. Should be above .6-.75 volts at idle with little or no switching under .5 volts.
Page 3 of 3 < 1 2 3
