Building a pole barn
by SVTCobra
05/04/16 09:44 PM
Hemorrhoids ?
by Merkava_4
05/04/16 09:40 PM
Well, I jumped on the ecoboost bandwagon...
by tomcruise
05/04/16 09:18 PM
2016 Audi S3 - EA888 Gen 3 - Factory Fill - 2007mi
by agpatel
05/04/16 09:16 PM
Can you live without credit cards?
by motor_oil_madman
05/04/16 09:04 PM
OC on W201 with LiquiMoly Leichtlauf HT 5W-40
by IllinoisSparky
05/04/16 08:54 PM
The Nooner
by MolaKule
05/04/16 08:14 PM
how often are you guys buying new tires
by bowlofturtle
05/04/16 07:56 PM
Why are some experienced people so conceited?
by motor_oil_madman
05/04/16 07:49 PM
alternative to Netstumbler...
by daves66nova
05/04/16 07:05 PM
Unable To Play Burned CD's in Car Player
by sleddriver
05/04/16 06:58 PM
Visiting Hudson Bay?
by JHZR2
05/04/16 06:54 PM
NatedeScate, Bogie69, Cali, Fyko, Palmer
57794 Registered Users
104 registered (alcyon, 06AllAmerican, abycat, 19jacobob93, 2KBMW, 11 invisible), 1 Guest and 0 Spiders online.
57794 Members
66 Forums
248484 Topics
Page 1 of 3 1 2 3 >
#3453682 - 08/12/14 03:55 PM Failed CA emission - high NO
InvalidUserID Offline
Loc: Bay Area, CA
My '96 3.8L Camaro failed it's first California emission test. It's gotten near the maximum allowed before but that was a HC issue which wasn't an issue this time. This time it failed due to high NO numbers.
I don't have any CEL or any rotten smells coming from the car. Mods are an intake, headers, high-flow cat and exhaust system but I've had all those the past 2-3 checks and haven't seen numbers like this. The NO numbers were about half in the two previous emission checks.
Where to start? Plugs, wires, fuel filter, O2 sensors, etc are all under 2 years and less than 12k old. Cooling system just drained/refilled. The EGR valve, as I understand, might be a culprit and it's probably near 8 years old and 80k on it though again, no CEL.
What else would contribute to a doubling NO test count?
My Cars aka old reliables:
- '96 Camaro 3800 II
- '97 4.0 Grand Cherokee
- '99 Civic EX
#3453687 - 08/12/14 04:00 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
eljefino Offline
Loc: ME
EGR likes backpressure. Root out the passages. Cool the engine off... rad flush.
Edited by eljefino (08/12/14 04:06 PM)
#3453690 - 08/12/14 04:06 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Chris142 Offline
Loc: apple valley, ca
it may be a bad cat. especially an aftermarked cat
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3453706 - 08/12/14 04:19 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Loc: Bay Area, CA
Found info on the cat. Carsound cat, installed in '08, approx. 20k on it.
- '99 Civic EX
#3453710 - 08/12/14 04:22 PM Re: Failed CA emission - high NO [Re: Chris142]
Bladecutter Offline
Loc: Dacono, CO
The entire EGR system should be inspected.
Also, how hot was your car before the test?
This is important for NOx.
If the EGR system isn't plugged or have a bad component, then you will need a new convertor.
BC.
2014 Mazda CX-5 Touring (Soul Red)
2015 Porsche Cayman
2007 Ducati 848
1988 Honda Hawk GT
#3453711 - 08/12/14 04:26 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
paulo57509 Offline
Loc: Tracy, CA
Typical and common things to consider:
Vacuum leaks, lean mixture, over advanced timing, in-operative EGR valve, plugged or partially plugged EGR passages, aftermarket non-CARB converter.
I'd look at the EGR system first.
I'd put a lean mixture down on the list of things to look at. You do have excess O2 but I don't think it's enough to affect the NOx readings.
If you have your previous year test results, it might help to compare the measured numbers. Perhaps there's a trend that might point you in the right direction.
I'd throw in the time table of when you made the engine mods for comparison purposes as well.
Edited by paulo57509 (08/12/14 04:27 PM)
1987 Chevrolet Camaro IROC-Z 5.0L
1987 Acura Legend L Coupe 2.7L (5-Speed)
1992 Lumina Euro Coupe 3.1L
1998 Lexus LS400
2003 GMC Safari
#3453712 - 08/12/14 04:27 PM Re: Failed CA emission - high NO [Re: Bladecutter]
Loc: Bay Area, CA
BC.
Should have added that info about temperature.
I had driven the car on the highway about 30 miles to the testing shop. It was shut off for approx. 5 minutes before they put it on the machine.
Is it likely the EGR valve or cat?
- '99 Civic EX
#3453723 - 08/12/14 04:40 PM Re: Failed CA emission - high NO [Re: paulo57509]
Loc: Bay Area, CA
Engine mods were in '06 so I've had three passing emission tests since then.
Dug up the last three emission tests, NO is really the only thing that has consistently been high.
2008: 15mph measure was 394, max is 424. 25 mph measure was 138, max is 711.
2010: 15mph measure was 209, max is 424. 25 mph measure was 312, max is 711.
2012: 15mph measure was 159, max is 424. 25 mph measure was 248, max is 711.
Since it's such a rarely driven vehicle, I haven't had to change much on it due to mileage.
Cat is CA legal, made sure that part was kosher before I purchased it.
- '99 Civic EX
#3453750 - 08/12/14 05:04 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Bluestream Offline
Loc: Waterloo, ON
Higher than normal NOX emissions may be caused by:
-an overheated engine
-Lean air/fuel mixtures
-Vacuum leaks
-over advanced ignition timing
-Defective EGR system
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#3453761 - 08/12/14 05:14 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
EricF Offline
Loc: SF Bay Area
The EGR is the first place to look at.
Probably just needs a very good cleaning, not just the valve, but all the ports, hoses and lines. hose them with carb spray.
A good run on the freeway would definetely help break that stuff up too.
I'd also do a seafoam de-carbonization and also a good freeway run.
I wouldn't be to concerned with the cat being faulty at this point. Your HC's are very low and CO is next to nothing.
This really is pointing to a plugged up EGR system.
Looking at
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#3453785 - 08/12/14 05:37 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
901Memphis Offline
Loc: Northern Kentucky
CRC Guarenteed to pass? High PEA content, won't hurt!
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3453797 - 08/12/14 05:52 PM Re: Failed CA emission - high NO [Re: Chris142]
JHZR2 Offline
Loc: New Jersey
Agreed. My 318i doesnt even have EGR. Failed NOx once, replaced it with a Magnaflow, barely passed. Replaced it with an OEM one, and passed with flying colors...
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/915639
ONLY EVER BUY OEM if you plan on doing anything besides dumping the car.
I learned that at my own expense. The aftermarket cat was barely good enough to improve numbers compared to my OE cat which was not converting NOX. New OE, NOx was at 7. All the other measured items had substantial improvements percentage wise but nowhere near the swing in number values.
#3453814 - 08/12/14 06:04 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Skid Offline
Loc: USA - Southern California
I thought you generally didn't have to go on the rollers in California anymore for year 2000+ cars. Just visual inspection and a code check.
Anyway, pressure check your cooling system and check for leaks. A hot cylinder head will raise NOx.
Edited by Skid (08/12/14 06:05 PM)
Edit Reason: whoops... didn't realize it was a '96.
#3453824 - 08/12/14 06:13 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Gokhan Offline
Loc: Los Angeles, California
Leaner mixtures result in higher NO_x and lower HC. Richer mixtures result in lower NO_x and higher HC. If you can adjust the mixture, do so.
Check the EGR system, which reduces the NO_x. See if it's working. If it's not working, it could be because of an EGR valve blocked with heavy carbon deposits or a torn EGR-vacuum-modulator diaphragm. Carbon deposits on the EGR valve can be removed using a flat screwdriver as a pick along with a brake-cleaner solvent.
In your car, the most likely candidate is the carbon deposits on the EGR valve. It also doesn't seem to have an EGR vacuum modulator but a solenoid. So, check if the solenoid is working as well.
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3453869 - 08/12/14 06:47 PM Re: Failed CA emission - high NO [Re: InvalidUserID]
Loc: Bay Area, CA
Thanks for all the input everyone. I've never failed an emission test before (come close, but never failed) so it's something new to worry about.
I've had the car for the last 14 years and 140k miles and haven't cleaned any EGR related items, just replaced the valve many many years ago. Come to think of it, I don't think I've ever replaced any vacuum hoses/lines either.
And in case anyone else is a visual person like me, here are the previous three passing tests.
- '99 Civic EX
Page 1 of 3 1 2 3 >
