Does this tail pipe pic tell you anything?
by LeakySeals
05/31/16 04:38 PM
Security Camera system
by Alfred_B
05/31/16 04:10 PM
Valvoline is going to be listed on the NYSE
by demarpaint
05/31/16 03:46 PM
Rislone or stp ethanol fuel treatment
by Indiana79
05/31/16 03:17 PM
Super Tech #3614 CUT OPEN
by car51
05/31/16 03:03 PM
Flight Tracker
by Eddie
05/31/16 02:33 PM
Art and ugly are separated by a fine line
by HTSS_TR
05/31/16 02:27 PM
2013 Ram 1500 Vibration Issue
by 757guy
05/31/16 11:21 AM
Speed & Temperature ratings vs cold PSI
by badtlc
05/31/16 10:52 AM
Worthy of a news story??
by andrewg
05/31/16 10:13 AM
Gorilla Shooting...decaying moral values?
by Smokescreen
05/31/16 09:53 AM
Oil Change Frequency - 04 Neon
by racer12306
05/31/16 09:15 AM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
80 registered (Branson304, bbhero, Atesz792, bdcardinal, Alfred_B, BeerCan, 10 invisible), 1986 Guests and 328 Spiders online.
58031 Members
66 Forums
249634 Topics
#3453152 - 08/12/14 07:44 AM Outer Tie Rods
Char Baby Offline
Loc: Western NY
I just installed the two outer tie rods on my '04 Altima. The castle nut(tie rod to steering knuckle) torque spec is 22-28 ft.lbs. Seems a bit low to me. I went 30 ft.lbs. on my beam style torque wrench as I was on my back, looking upward(no sarcasm laugh )
Any opinions on this spec?
Should I have gone a bit more?
Thanks,
CB
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3453171 - 08/12/14 08:00 AM Re: Outer Tie Rods [Re: Char Baby]
eljefino Offline
Loc: ME
Is it a nylock nut or did you have to stuff a pin through it?
Spec should be so-many ft lbs then crank it some more to line up the holes so you can stick the pin in, on a true castle nut.
#3453175 - 08/12/14 08:02 AM Re: Outer Tie Rods [Re: Char Baby]
Char Baby Offline
Loc: Western NY
Yes, there is a castle nut with cotter pin. And this is exactly what I did! Got close as I could see(looking up) and then lined up the hole for the cotter pin. smile
If I torqued the castle tooooo tight, is there a risk of pulling the joint out of the socket(over time)?
Edited by Char Baby (08/12/14 08:04 AM)
"Retired"
#3453187 - 08/12/14 08:21 AM Re: Outer Tie Rods [Re: Char Baby]
kschachn Offline
Loc: Upper Midwest
No it won't pull it out, the pin should not be bottomed out such that the socket is contacting the knuckle. If it is, then it would restrict movement. You might pull the threaded portion of the pin off the tapered part if it was way overtightened. Most likely it will just make it harder to get apart for the next time.
And you are right, it doesn't seem that tight. But it's the same for my cars and so far nothing has ever come apart smile
1994 BMW 530i, 205K
1996 Honda Accord, 216K
1999 Toyota Sienna, 344K
2000 Toyota ECHO, 252K
#3453193 - 08/12/14 08:26 AM Re: Outer Tie Rods [Re: Char Baby]
Char Baby Offline
Loc: Western NY
Thanks, I feel much better now! smile
"Retired"
#3453336 - 08/12/14 10:51 AM Re: Outer Tie Rods [Re: Char Baby]
Dufus2 Offline
Loc: Virginia
Normally you would tighten to around 40-50 and back off re-torque to 20+ to align pin. This is a Morris taper and does not require much torque once it is seated. Over tightening can split the casting or make it impossible to separate.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
#3453473 - 08/12/14 12:44 PM Re: Outer Tie Rods [Re: Dufus2]
Char Baby Offline
Loc: Western NY
Thanks! smile
"Retired"
