Air filter wrap
by Duffyjr
57 minutes 43 seconds ago
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
Today at 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
Today at 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
Today at 09:34 PM
Choose for me
by Duffyjr
Today at 09:26 PM
Help w/Transmission Drain & Fill
by klt1986
Today at 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
Today at 08:10 PM
Group 5 synthetic oil
by Brayden
Today at 08:07 PM
Ultra
by RubentheIowan
Today at 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
Today at 08:03 PM
CEL Code P2097, 2010 Mazda 6 with 2.5L I-4
by Snyperx
Today at 08:01 PM
Laser scope on a Henry .22?
by Chris142
Today at 07:58 PM
Spinnizle, JustinL, abdoezzat, JanK, paydase
57755 Registered Users
74 registered (AntsinmyEyes, barkingspider, 901Memphis, AirgunSavant, 2015_PSD, 7 invisible), 1231 Guests and 257 Spiders online.
57755 Members
66 Forums
248280 Topics
#3451144 - 08/10/14 05:00 AM Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi
phteven Offline
Loc: Australia
Hi guys, This is my first post so apologies if there are errors.
After my first oil change by Subaru I suspected that the oil used was not as specified by the manual which states use 5w-30 but NEVER to use 0w-20 which I suspected they used. My analysis was done by ALS Tribology here in Australia. The report states that viscosity was low due to fuel dilution. I suspect it was low because they used 0w20. Here are the results...
COMPONENT Kms 16900
MACHINE Kms 16900
OIL Kms 4400
OIL MAKE Unidentified
OIL TYPE SAE
OIL GRADE SAE 5W30???
Physical Tests
Water (%) <0.1
Viscosity (cSt,100C) 8.3
Fuel (% by G.C.) 1.2
Dispersancy Pass
Oxidation (Abs) 13.5
Nitration (Abs) 8.4
Total Base Number (FTIR) 8.3
Now my questions to you all is:
1) Would a 1.2% fuel dilution cause a shearing of viscosity to 8.3 if 5w30 oil had originally been used? (My basic understanding is that if that oil had been used minimum value should be 9.3 and max 12.49 @100deg C.)
2) Is a 1.2% fuel dilution after 4400kms (2500Mi) and acceptable value for a direct injection, turbo, high compression engine (10.6:1) such as the FA20DIT?
3) Are these totally acceptable values, the correct oil was used and I am overreacting?
Any input appreciated. If you require anymore information please let me know and I will provide it to you.
Thanks all.
Edited by phteven (08/10/14 05:05 AM)
#3451166 - 08/10/14 06:23 AM Re: Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi [Re: phteven]
HKPolice Offline
Loc: Toronto, Canada
Fuel dilution is acceptable if you made a lot of short trips, but could be an issue if you drove a lot of hwy mileage.
The 8.3 Vis is very suspect if you weren't redlining the engine every day because a full synthetic 5w30 (Subaru manuals state that all turbo engines req full synth) will never shear that fast under normal conditions. Given that most 0w20 oils start with a Vis of ~8.5, it does look likely that it was put in your car.
What made you suspicious in the first place? Did the report include any wear metal data?
#3451198 - 08/10/14 07:18 AM Re: Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi [Re: phteven]
Greasymechtech Offline
Loc: Paradise of Florida
any wear numbers?
wait to the next UOA to see if visc and fuel is still an issue
At what point should a lurker start posting :-)
#3451711 - 08/10/14 05:16 PM Re: Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi [Re: phteven]
phteven Offline
Loc: Australia
Thank you both for your responses.
HK, what made me suspicious was that the engine was making more noise than usual after I picked it up for service. When I checked my receipt it stated that 0w20 had been used. When I approached the service guy he said that the engine only used 5w30 and there is no way that they would have used 0w20 and it was an administration mistake.
Greasymechtech, The thing is I cant keep getting the oil analyzed here in Australia as that test was pretty expensive at $70Au or $65us per examination. Another thing is that the service interval for the vehicle is 12500kms or 7767Miles, If I had of let that oil go till next service it almost certainly would have been too degraded by fuel contamination to do its job. Wouldnt you agree?
I do have the metal wear data for you guys. It all appears acceptable, but I feel if I had left that oil in the engine any longer it would have caused damage so I did an oil and filter change to the correct oil 5w30 GF-5. Here is the wear:
Metals (ppm)
Iron (Fe) 18
Chromium (Cr) <1
Lead (Pb) 2
Copper (Cu) 20
Tin (Sn) <1
Nickel (Ni) <1
Aluminium (Al) 7
Titanium (Ti) 4
Silver (Ag) <1
Contaminants and Additives (ppm)
Silicon (Si) 64
Sodium (Na) 2
Potassium (K) <1
Boron (B) 21
Calcium (Ca) 2208
Zinc (Zn) 871
Phosphorus (P) 709
Magnesium (Mg) 12
Molybdenum (Mo) 67
Cadmium (Cd) <1
Sulphur (S) <2000
Thank you again for your input. I really appreciate your help. smile
Edited by phteven (08/10/14 05:19 PM)
#3451721 - 08/10/14 05:30 PM Re: Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi [Re: phteven]
We'll see in the future if more owners with this engine have similar UOAs.
With your climate, I wouldn't fear going a little thicker with the oil until more info is known. And, I would also keep a conservative <10000 km change interval.
Good luck and enjoy the vehicle.
#3451755 - 08/10/14 06:04 PM Re: Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi [Re: Greasymechtech]
phteven Offline
Loc: Australia
Thanks mate. Just to be safe ill be sticking to 6000km changes which is twice as often as prescribed by Subaru. Now if only I can get the dealer to put the correct oil in to start with. Im very angry about that.
Definitely an enjoyable car to drive. smile
#3452127 - 08/11/14 07:35 AM Re: Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi [Re: HKPolice]
bluesubie Offline
Loc: NJ
These cars indeed can shear Resource Conserving GF5 5W-30's down to a 20 grade in 2,500 miles or less, with or wiithout fuel dilution. If the OP's 5W-30 oil meets ACEA A3, then it's more likely that the oil would have stayed a 30 grade.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3442654
-Dennis
Edited by bluesubie (08/11/14 07:37 AM)
'04 Subaru Forester 2.5XT
Motul X-clean 5W-30
#3453381 - 08/12/14 11:32 AM Re: Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi [Re: phteven]
ARCOgraphite Offline
Loc: N.H, U.S.A.
It reads like a low quality 30 grade ILSAC oil with moderate fuel dilution (~3oz). I think your KV would be in the high 7's if you used Idemitsu 20 grade and had 1.5% fuel. Engine just went through the nastiest part of break-in, so shear and fuel dilution are expected to be high.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#3455979 - 08/15/14 01:23 AM Re: Forester XT 14+ FA20DIT Subaru 5w-30??? 2500Mi [Re: phteven]
phteven Offline
Loc: Australia
Some great info to research here guys. Thank you all for taking the time to look at my results and reply.
I will post up my next results with a known oil and compare.
