New old ride
by SEBZX79
Yesterday at 11:25 PM
Motor Trend Visit with Valvoline
by tenderloin
Yesterday at 10:46 PM
Fixing Tractors a no-no, Are cars next?
by user52165
Yesterday at 10:38 PM
Cosmetic only or replace
by ram_man
Yesterday at 09:55 PM
Wooden Motorcycle Piston from Vietnam
by KeithS_NW_Ohio
Yesterday at 09:49 PM
Castrol Edge for hard-driven turbo + DI
by Atomic
Yesterday at 09:27 PM
2001 Camry LE V6 - Synthetic ATF Recommendation
by 01CAMRY
Yesterday at 08:39 PM
Delo 400?
by Sealbilly
Yesterday at 07:17 PM
Noob question about chain maintenance
by JeepWJ19
Yesterday at 07:00 PM
Rural King Full Synthetic Oil Sale...
by AnthemBassMan
Yesterday at 05:16 PM
Mobil 1 EP oil filter - Cross Reference
by Kung_Faux
Yesterday at 05:08 PM
sears SYWR $30 off $30 surprise
by eljefino
Yesterday at 05:03 PM
dewpoint, Luuey, Eskimio, Jngoose76, Ken_Clifton
58593 Registered Users
22 registered (Brad_C, autoguru_24, alcyon, AMC, 2 invisible), 940 Guests and 15 Spiders online.
58593 Members
66 Forums
252249 Topics
Page 1 of 2 1 2 >
#3453200 - 08/12/14 08:31 AM 80 VW Rabbit Diesel
Trigger Offline
Loc: Northern California
I just inherited a 80 VW Rabbit pick-up that is a Diesel. The truck had been sitting in a field for about 7 years. I brought it home on a trailer and hooked a battery to it and it fired up on the first try. I live in Northern California and we have the low sulfur fuel out here. My question is, do I need to or should I run some kind of additive in the fuel? I have read that the low sulfur blend can be hard on the older engines, especially the injector pumps themselves. If I should run an additive, what would you guys suggest? Thanks.
#3453211 - 08/12/14 08:42 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
Dufus2 Offline
Loc: Virginia
Definitely run a diesel additive like Diesel Kleen and a biocide to kill the stuff growing in the tank. I also add MMO and a little 2-stroke oil for added lubrication.
Mix the MMO at 4-oz for 10 gallons and a comparable amount of any two-cycle oil, no need to over do it.
You might have some fuel problems for a while if the car has been sitting. Algae will clog your fuel filters until you get it cleaned out, took several months in my Benz after it sat for eight years.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
#3453213 - 08/12/14 08:42 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
R80RS Offline
Loc: Wisconsin USA
A study done by the Southwest Research Laboratory several years ago listed several additives that provide lubricity to ULSD. According to the study, 2% Soy based biodiesel provided the best additional lubricity, followed by some commercially available additives.
I personally add TC-W3 2-cycle oil (at 1/2 oz per gallon) and either Power Service Diesel Fuel Supplement or Amsoil Diesel Injector Clean.
http://www.natbiogroup.com/docs/education/lubricity%20additive%20study%20results.pdf
2004 F150 228k mi. Pennz Plat HM 5w-20, Fram Ultra
2003 VW Jetta TDI, 221k mi. Amsoil HDD 5w-30, Mahle
#3453218 - 08/12/14 08:44 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
chrisri Online   content
Loc: Fiume, EU
No need really. Here we have a lot of old diesels, they work fine with low sulphur diesel.But with car sitting this long you can expect some issues with gaskets. Make sure you change fuel filter. Also OCI is limited on this cars because of fuel dilution of oil.
Edited by chrisri (08/12/14 08:45 AM)
99 FIAT Punto Sporting 16v ( Shell Helix Ultra 5w40 )
06 FIAT Stilo MW 1.9 Multijet (Selenia WR 5w40)
#3453220 - 08/12/14 08:46 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
javacontour Offline
Loc: Illinois
And stock up on window regulators for that car. I had an '81 and got pretty good at changing the regulator smile
The engine is gutless, but bulletproof. Acceleration is measured with a calendar. Leaking windows, window regulators and electrical gremlins are the primary downsides of the car.
network down, IP packets delivered via UPS -BOFH
#3453225 - 08/12/14 08:51 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
yvon_la Offline
Loc: quebec canada
nha ,no need to do much .you all need a jerry can tho.always fuel in 0% biodiesel station .you go to a (whatever % biodiesel and calculate about 1 to 2% bio per fuel tank .yep this mean if you baught a 20% biodiesel gallon you divide the gallon by 20 or 10 you can go up to 2 % bio.and no you cant run ulsd 0% bio all the time .it would break something .but at 1 or 2% biodiesel?you all be tired of the thing before it break .assuming the 7years kept the various seal moist
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3453278 - 08/12/14 09:48 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
Bandito440 Offline
Loc: NYS
Use B2 or B5 blends if you have that available, and Opti-Lube XPD if you don't.
'14 Grand Cherokee EcoDiesel
Pennzoil Euro L & OEM filter
#3453290 - 08/12/14 10:02 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
scurvy Offline
Loc: Chicago IL USA
Plan on sending the pump & injectors out to DFIS in Portland OR to be rebuilt. The evidence of seal shrinkage when going from high-aromatic LSD to low-aromatic ULSD is overwhelming and well documented. I would suggest you run a low blend of biodiesel (B20 or less) to help keep the seals pliable as long as you can get away with it, but nothing will save them in the long run aside from replacement with viton.
Actually, I would plan on doing a full timing belt on it ASAP - 7 years without being run likely makes for some awfully brittle spots in the belt. And don't buy prothe parts!
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#3453295 - 08/12/14 10:10 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
ctrcbob Offline
Loc: Mount Dora FL, Penfield NY, R...
Congratulations. FWIW, that truck is worth A LOT OF MONEY..
About twenty years ago, I took a job delivering parts for a local VW dealer. Used their old at the time Rabbit Diesel Pick-Up. Got around 44mpg day in and day out. A couple of the tech's had their own personal trucks. They and others were always looking for them and when found, the selling price was high. Price today has to be out of sight. In the six months I was there, the only thing that went wrong with it was the diesel pump stopped working. Rather than installing a new pump, the service dept removed the broken pump and sent it to a shop in town to have the pump rebuilt. (Cheaper that way). It was still running great last time I saw it.
Bob CTRC USN Ret.
Mount Dora FL, (It Could Be Worse)-
Penfield NY, (Nice Suburb)-
Roswell NM (Alien Central)-
2013 Mercedes E350 Cabrio
2011 Lincoln MKZ
#3453332 - 08/12/14 10:47 AM Re: 80 VW Rabbit Diesel [Re: scurvy]
2015_PSD Offline
Loc: SE Texas
+1 I had an 81 model and the belt skipped a tooth causing a valve to hit one of the pistons. Fixed it myself at a moderate cost, but you should not chance it.
PS...I managed 55MPG in it, so it will be a miser.
2015 F-250 PSD.................Delo 400 XLE 10W-30 + CQ
2014 Explorer LTD.............M1 AFE 0W-20 + FU
2010 Kawasaki BF750 4x4....RT6 5W-40 + OEM
#3453343 - 08/12/14 10:56 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
Donald Offline
Loc: Upstate NY
I had a 1980 VW Rabbit diesel. Nice car.
If a vehicle has a mechanical injector pump then adding some lubricant to the diesel fuel will ensure that the fuel has good lubricity.
I use Walmart TCW-3 oil at 1 oz/gallon.
There is an industry test for this called HFRR. In that test MMO made the diesel fuel worse (better using nothing than MMO). TCW-3 oil was a good one that is cost effective. If you Google HFRR you should find a few tests out there.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3453384 - 08/12/14 11:37 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
Rat407 Offline
Loc: North Carolina
Those VW diesel pickups go for some top dollar amounts on Ebay.
I would change out all the fluids and filters, as well as the timing belt. If you plan on keeping it a water pump change out wouldn't hurt, that way it is out of the way and while you are doing all the other maintenance just makes sense. Also stick with a VW thermostat. Don't bother with anything other brand.
Over heating is a major head gasket killer in these. It is easy to change out but as long as you keep an eye on the coolant temp and don't let it get hot you will be fine.
My little 91 Jetta TD is a great economy ride and if you take care of them they will last a long time.
A good place for parts is http://www.autohausaz.com/
I just run some AMSOIL Diesel Injector Clean in mine to keep things running smooth. I fill up about once a month and get 700 miles to a tank which works out to be 50mpg.
#3453392 - 08/12/14 11:44 AM Re: 80 VW Rabbit Diesel [Re: Trigger]
yvon_la Offline
Loc: quebec canada
Back then they had thermostat issue because of all the junk was in the coolant .now with long duration no silicate phosphate and other accronim I can recall .you won't have issue and if you mix it yourself make sure to use distilled water (avail at Walmart)
Truck driver
#3453455 - 08/12/14 12:31 PM Re: 80 VW Rabbit Diesel [Re: Trigger]
abycat Offline
Loc: grande prairie AB
awesome! The injector pumps are very easy to turn up. Get lots more power out of it. Just make sure it doesn't run away. a hair before that and you should get some good power.
2004 f350 6.0
2011 nissan versa hb
#3453464 - 08/12/14 12:38 PM Re: 80 VW Rabbit Diesel [Re: Trigger]
NHGUY Offline
Loc: USA
How do you like the chest to steering wheel clearance? Back in the day,VWs were criticized for their lack of cab space as opposed to the similar (but shorter bed) Dodge Rampage.Whereas the VW favored cargo above all else,the Dodge went for cabin comfort.
Page 1 of 2 1 2 >
