Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
Left my lights on and battery died.
by joegreen
02/12/16 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
02/12/16 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
02/12/16 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
02/12/16 06:54 PM
Cost to replace windshield.
by Oldmoparguy1
02/12/16 06:44 PM
Oil Life Monitor vs. Mileage vs. Time
by HOG
02/12/16 06:24 PM
Carrier A/C moving ALL production to Mexico.
by GiveMeAVowel
02/12/16 06:23 PM
ZDDP MAXX vs ZDDPlus
by 007
02/12/16 06:02 PM
Got a new jump starter, for the big boys
by 901Memphis
02/12/16 05:20 PM
S2000 valvetrain at 184K miles
by robertcope
02/12/16 04:58 PM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
124 registered (90crvtec, 1989outlaw, 901Memphis, 2cool, 2002 Maxima SE, ammolab, 14 invisible), 1416 Guests and 197 Spiders online.
56901 Members
66 Forums
244620 Topics
#3452977 - 08/11/14 10:56 PM Leftover Synpower, shall I mix it with SOPUS oil?
wing0 Offline
Loc: Ontario, Canada
Got 1L 5W30 Synpower SN oil left.
I only got this jug due to a sale a while back and now I am stocked up with SOPUS oil - PYB, Motomaster F1(similar to Formula Shell) and PP.
What should I do with the leftover? The add. pack seems to use sodium as the cleaning agent while SOPUS focuses on using calcium and almost no sodium. I'm not planning to buy more synpower or valvoline soon due to current stockpile.
I have two candidate to put this 1L in.
98 Civic D16 engine that takes 3.3L. Currently has Synpower, want to use PYB next.
01 RX300 1MZFE engine that burns roughly 1L in an OCI when it runs on the highway(my guess). Currently, running Motomaster F1 and no consumption yet for 5K km.
1. Mix Synpower with PYB and use in next OCI on Civic in 2 months or so. Synpower will comprise approximately 30% of total capacity.
2. Dump it into RX300 as makeup oil if it happens. Although, I have leftovers of Motomaster too after each oil change.
Which path shall I take?
#3452983 - 08/11/14 11:05 PM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
901Memphis Online   content
Loc: Northern Kentucky
Use as makeup oil definitely
2002 Buick Century 118k - Built 4T65e - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317
#3452987 - 08/11/14 11:09 PM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
abycat Offline
Loc: grande prairie AB
blasphemy! How dare you even think of diluting the sopus oil with that snake oil garbage. Just kidding. I would for my truck but for my car I like to keep it the same oil. doubt it matters though.
2004 f350 6.0
2011 nissan versa hb
#3452988 - 08/11/14 11:09 PM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
CHARLIEBRONSON21 Offline
Loc: MEMPHIS, TN
I wouldn't mix with PYB. Too off oil is a a good idea.
'10 Fusion Hybrid: 5w20 MC/MC
'15 Civic Si: 0W20 HGMO
'13 Fusion Hybrid: 5w20 PUP/MC
'14 Odyssey: 0w20 HGMO/FU
'93 Civic: 5W30 PUP/TG
#3453001 - 08/11/14 11:49 PM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
sicko Offline
Loc: Virginia
Either one works. Although it's not ideal, the oils are compatible so you can do either of the options you mentioned without any issues/concerns.
Personally, I'd use it as top up oil. But like I said, you can do either of the options you mentioned without any issues.
#3453003 - 08/11/14 11:52 PM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
You don't have a lawnmower or snowblower you can put it in?
#3453044 - 08/12/14 03:46 AM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: abycat]
Oil Changer Offline
Loc: Michigan
Give that garbage to someone you speak to but don't really like. Not kidding.
#3453071 - 08/12/14 05:37 AM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
wemay Offline
Loc: South Florida
Mix away and don't worry about it. Every oil youve mentioned says 'compatible with all other motor oils.'
Hyundai
14 Sonata GLS 2.4L --> Valvoline SynPower 5W20
13 Santa Fe Sport 2.0T --> Mobil1 EP 10W30
#3453145 - 08/12/14 07:39 AM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
Dallas69 Offline
Loc: Texas
You can mix any oil these days and not have any issues
This is not 1970,even though I wish it was
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Valvoline Maxlife 5-30
Motorcraft filter
#3453210 - 08/12/14 08:41 AM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
ARCOgraphite Offline
Loc: N.H, U.S.A.
I topped off with sopus (5w20 PP) on my Fit which was running 0w20 Synpower - the engine responded well to the moly and it didn't blow up.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#3453238 - 08/12/14 09:03 AM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
HKPolice Offline
Loc: Toronto, Canada
Mix it in the D16 next OC since it already has valvoline in it.
#3453721 - 08/12/14 04:38 PM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: Oil Changer]
fdcg27 Online   content
Loc: OH
Any number of us here as well as many elsewhere have had good results using all of "that garbage", including the ATF.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3453756 - 08/12/14 05:12 PM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: wing0]
raytseng Offline
Loc: CA
The engine probably has about a good chunk of old oil in it compared to dry when you do a drain fill; so unless you're double changing (flushing) your oil every time; then you're mixing anyway.
#3453773 - 08/12/14 05:26 PM Re: Leftover Synpower, shall I mix it with SOPUS oil? [Re: 901Memphis]
SilverC6 Offline
Loc: Southeast
+1....Use as make up oil late in the OCI.
'04 Mazda RX8 5W30 Valv Synpwr
'10 &'11 Camry 5W-20 PU
'11 Landcruiser 5W20 PU
'13 BMW 550IX BMW 5W30
'08 BMW Z4M Coupe TWS 10W60
'13 BMW M6 BMW 5W30
