Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
Troy Bilt Pony
by OSUFan86
02/10/16 06:43 PM
$1.33 for a GALLON of 87!
by Vern_in_IL
02/10/16 06:30 PM
Eating out, beware you all
by CourierDriver
02/10/16 06:13 PM
Best Sponge For Washing Cars
by George7941
02/10/16 06:08 PM
Old school (ethanol) and (leaded) fuels
by mjoekingz28
02/10/16 05:37 PM
Opinions on this oil filter relocation setup
by bspag
02/10/16 04:42 PM
E-brake tightening on Cobalt Chevrolet
by mjoekingz28
02/10/16 04:32 PM
Mobil 1 EP rollbacks at local Walmart
by HTSS_TR
02/10/16 04:29 PM
Miningman, pocketdrummer, bspag, Lana, phem0r
56883 Registered Users
117 registered (3800Series, A1O, 01rangerxl, 901Memphis, 69GTX, 97f150, 12 invisible), 1549 Guests and 247 Spiders online.
56883 Members
66 Forums
244525 Topics
#3452825 - 08/11/14 08:13 PM Iveco 6.7L, New Holland TS135a
sdan27 Offline
Loc: Michigan
Eng Time 11306, 11601
Oil time 1002, 1297
Iron 35, 36
Nckl .6, .4
Chrm 1.3, 1.1
Tit. .5, 0
Copp 1.3, 1.4
Alum 3.8, 3.9
Tin. 0, .3
Lead 4.1, 2.8
Boro 108, 93
Cal. 4063, 3904
Magn 25, 23
Moly 105, 104
Sodi 2.9, 2.4
Phos 1463, 1359
Sulf 4369, 5770
Zinc 1779, 1567
Visc 15.24, 16.39
Oxid 40, 56
Nitr 42, 67
Sulf 42, 52
Soot .4%, .9%
Using a Service Pro 15w-40. UOA looks awesome except my viscosity is up into the 50w range. Is this something I should be concerned with?
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#3452891 - 08/11/14 09:07 PM Re: Iveco 6.7L, New Holland TS135a [Re: sdan27]
Rand Offline
Loc: NE,Ohio
its on the thick edge of 40wt..thin 50wt
thats directly from the near 1% soot loading.
Edited by Rand (08/11/14 09:14 PM)
2015 Forester I-Premium 6MT
#3452997 - 08/11/14 11:30 PM Re: Iveco 6.7L, New Holland TS135a [Re: sdan27]
m37charlie Offline
Loc: Alaska
I think you should consider changing it; the base oil may be breaking down. On my Delvac 1 SHC 5W40 after 17500mi/500hr the vis actually dropped from 14.4 to 13.6 with 0.7% soot.
0.9% soot shouldn't be enough to thicken a CI4+ oil, which has even more dispersants in it than my ACEA E4 oil.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota Bandeirante OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#3453052 - 08/12/14 04:35 AM Re: Iveco 6.7L, New Holland TS135a [Re: sdan27]
dnewton3 Offline
Loc: Indianapolis, IN
Ox, Ni, Soot all rising.
Wear seems unaffected for now, but who knows how long that will be able to be sustained, given the shift in Vis due to general thickening from contamination?
Not time to OCI yet, but I'd keep a closer eye on the progress; perhaps UOA a bit more often?
You ask if you should be "concerned" ... I'd say Yes. But do not interpret that as a cause for panic. You simply are going to want to pay closer attention to the wear metals, and look for an uptick that would indicate the lube has reached a useful end. Overall the Service Pro has been an outstanding performer in nearly every application youv'e put it in. But there's always a niche here or there that may not respond as well. It's not so much the lube at fault here; perhaps this engine is just hard on any lube. Perhaps try a different lube and see if similar things happen. This is about fact finding, not blame. What you seek to know is if this is a concern about lubes, or a concern about the OCI duration.
Keep us posted!
Edited by dnewton3 (08/12/14 04:35 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
