Incandescent Light History and Metallurgy
by MolaKule
06/29/16 09:54 PM
Pass Word Changed?
by ls973800
06/29/16 09:26 PM
Best canned Mandarins
by aquariuscsm
06/29/16 09:11 PM
Super Short Commute OCI?
by randomhero439
06/29/16 09:08 PM
Good News About The Fram Ultras.. No Louvers...
by crazyoildude
06/29/16 08:57 PM
Citgo Supergard 0W-16
by addyguy
06/29/16 08:06 PM
MolaBrew
by synman
06/29/16 07:27 PM
Honda tensioner
by greasegunn
06/29/16 07:00 PM
Car&Driver opinion on Toyota weird styling
by HTSS_TR
06/29/16 06:01 PM
Old house woes
by OVERKILL
06/29/16 05:55 PM
Toyota Factory Fill???
by Doog
06/29/16 05:43 PM
Time to Replace?
by GMFan
06/29/16 05:20 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
87 registered (87sammy, alcyon, 3800Series, AirgunSavant, 2015_PSD, 13 invisible), 1670 Guests and 9 Spiders online.
58322 Members
66 Forums
251004 Topics
#3452064 - 08/11/14 01:34 AM Formula Shell 5w-30 SM
bblank Offline
Loc: ohio
MILES ON OIL 1,593 MILES ON UNIT 50,318 SAMPLE DATE 7/31/14 ALUMINUM 2 CHROMIUM 0 IRON 3 COPPER 3 LEAD 4 TIN 2 MOLY 289 NICKEL 0 MANGANESE 0 SILVER 0 TITANIUM 0 POTASSIUM 10 BORON 36 SILICON 11 SODIUM 61 CALCIUM 1776 MAGNESIUM 6 PHOSPHORUS 672 ZINC 774 BARIUM 0 SUS @ 210 59.3 cST @ 100 10.03 FLASHPOINT 400 FUEL <0.5 ANTIFREEZE % 0.12 INSOLUBLES % 0.1 WATER % 0.0 2002 S10 4.3 V6, oil was in use for 15 months. Checking for coolant in the oil. The fill was 4 qts of the formula shell 1/2 qt of Rotella 15w-40
#3452086 - 08/11/14 04:44 AM Re: Formula Shell 5w-30 SM [Re: bblank]
Char Baby Offline
Loc: Western NY
Reads like the nutritional value on the side of a candy bar wrapper. smile
The wear metals are low and the additive package is about normal for an SM oil. Silicon(check the air filter seal) and sodium(possibly coolant or the oil itself) are up but, not sure if this is cause for alram!
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3452104 - 08/11/14 05:57 AM Re: Formula Shell 5w-30 SM [Re: bblank]
bigt61 Offline
Loc: Virginia
Looks good - those 4.3L Chevy engines are unkillable - you can run anything in them and they don't complain. Report back in 10 years.
92 Suburban 2500 7.4L 58k M1_5w30 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 29k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#3452198 - 08/11/14 09:03 AM Re: Formula Shell 5w-30 SM [Re: bigt61]
ThirdeYe Offline
Loc: Walker, MI
Unless the intake manifold gasket gives out. The same can be said for the 3800 Series II.
Anyways, it does look like there is coolant in this sample, as evidenced by the sodium and potassium. Rotella and Formula Shell do not use sodium in their add-pack as far as I know.
99 Pontiac Firebird - 93k - Havoline 10W-30/Purolator PureOne PL10111
08 Scion tC - 119k - RP 0W-20/Purolator Classic L14477
#3452203 - 08/11/14 09:10 AM Re: Formula Shell 5w-30 SM [Re: bblank]
jstutz Offline
Loc: NC
Mine had a lower intake manifold leak that eventually leaked enough coolant into the oil that it made the lifters stick. After fixing the gasket with a updated one, no more issues. I believe these engines are known for leaking manifold gaskets.
#3452293 - 08/11/14 11:00 AM Re: Formula Shell 5w-30 SM [Re: bblank]
bblank Offline
Loc: ohio
Should I flush out the antifreeze and go to something like peak global. Would this buy me more time till I get it fixed. Once the damage is done it will only get worse. I watched videos on the internet on how to replace the gasket. I don't know if I want to tackle something like this. I tried for 3 days to code block or imaged the results on the test forum that was the best I could do. I did figure out how to delete post and highlight.
#3452373 - 08/11/14 12:19 PM Re: Formula Shell 5w-30 SM [Re: bblank]
ThirdeYe Offline
Loc: Walker, MI
I think you'd have more luck using a stop leak in your coolant rather than changing the type of coolant. We had good luck using Bar's Stop Leak in my sister's 2001 Windstar that had a blown head gasket.
#3452509 - 08/11/14 03:20 PM Re: Formula Shell 5w-30 SM [Re: bblank]
jstutz Offline
Loc: NC
No point in my opinion to changing the coolant until you fix the problem. Not sure about the stop leak stuff and have read bad things about it. if you use it be just follow the directions carefully. I believe most of them you need to remove the T-stat first but not sure. I have read about them becoming sticky if you dont remove it before adding the additive. I did mine myself with the Haynes manual in about 5-6 hours. I believe you will pay 500 dollars or more to pay a shop to do it. Here is a link that closely resembles what you will be in for if you tackle this job
http://www.handymanlyness.com/archives/a...e_99_Jimmy.html
#3452588 - 08/11/14 04:54 PM Re: Formula Shell 5w-30 SM [Re: Char Baby]
fdcg27 Offline
Loc: OH
The Potassium level combined with the Sodium indicates a LIM gasket failure, IMHO.
The report even indicates that some coolant is in the oil, which your rarely see even when this is the case.
It isn't bad yet, since wear metals are okay, but I'd attend to it ASAP.
This UOA is a good example of how valuable they can be.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3452822 - 08/11/14 08:12 PM Re: Formula Shell 5w-30 SM [Re: Char Baby]
deven Offline
Loc: Massachusetts
crackmeup
Proud user of ROYAL PURPLE products!
#3452907 - 08/11/14 09:20 PM Re: Formula Shell 5w-30 SM [Re: bblank]
yvon_la Offline
Loc: quebec canada
Last time I had engine gasket issue,Mercedes had messed up .how they made a great engine sold in EU, I believe then dd was wanting those ,so Mercedes raised the HP and all to 425 but the issue was there wasn't enough clamping in the head area so every 18 month I needed a head gasket job on those series 55 Detroit diesel (Mercedes)
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3452961 - 08/11/14 10:25 PM Re: Formula Shell 5w-30 SM [Re: bblank]
Hollow Offline
Loc: the South
Good Lord, I could barely read that.
Here:
Quote:
2002 S10 4.3 V6, oil was in use for 15 months. Checking for coolant in the oil. The fill was 4 qts of the formula shell 1/2 qt of Rotella 15w-40.
MILES ON OIL 1,593
SAMPLE DATE 7/31/14
ALUMINUM 2
CHROMIUM 0
IRON 3
COPPER 3
LEAD 4
TIN 2
MOLY 289
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 10
BORON 36
SILICON 11
SODIUM 61
CALCIUM 1776
MAGNESIUM 6
PHOSPHORUS 672
ZINC 774
BARIUM 0
SUS @ 210 59.3
cST @ 100 10.03
FLASHPOINT 400
FUEL <0.5
ANTIFREEZE % 0.12
INSOLUBLES % 0.1
WATER % 0.0
#3452996 - 08/11/14 11:27 PM Re: Formula Shell 5w-30 SM [Re: bblank]
901Memphis Offline
Loc: Northern Kentucky
Haha much better with the new format.
Keep the oil changed frequently (2k) with dino and run it til it's done due to the intake leak.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3453274 - 08/12/14 09:43 AM Re: Formula Shell 5w-30 SM [Re: bblank]
bigt61 Offline
Loc: Virginia
Just use these - problem solved.
or these from NAPA - same thing but cheaper.
70 Camaro 5.7L 59k
