Battery or starter
by Dallas69
08/27/16 07:56 AM
Napa Syn 15w50 to replace BradPenn 20w50 in 454bbc
by FlyNavyP3
08/27/16 07:51 AM
Real Main Seal Leak ? ? ?
by larryinnewyork
08/27/16 07:35 AM
Gov't wants to lower speed limits for trucks
by JetStar
08/27/16 07:11 AM
GM 55560202 longlife cut open - 10782km
by turboseize
08/27/16 04:54 AM
Coolant Question.
by Farmer
08/27/16 04:20 AM
Stocking up for the Eco
by buck91
08/27/16 12:25 AM
Mobil 1 10w40 HM
by SubyRoo
08/27/16 12:16 AM
What type of glue for door panels?
by Nick1994
08/27/16 12:07 AM
Painting rear of chrome bumpers
by buck91
08/26/16 11:09 PM
Walmart Rifle Clearance
by hatt
08/26/16 10:44 PM
Vehicles That Must Idle For Long Periods Of Time
by BlueOvalFitter
08/26/16 10:30 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
77 registered (AirgunSavant, 4WD, A310, 97f150, 3800Series, 2009Edge, 4 invisible), 1293 Guests and 37 Spiders online.
58935 Members
66 Forums
253614 Topics
#3450493 - 08/09/14 11:20 AM 2011 Tundra, Amsoil signature 0W-20, 9.5K miles
btanchors Offline
Loc: Herndon, VA
This is the Final Report on my 2011 Tundra Crewmax 5.7 4WD - I just sold it this week. With my daughter moving across country to go to college, we would have had 4 vehicles and only 3 drivers, as my daughter must live on campus for two years and won't need a car. Plus, there was one full year of tuition, room and board tied up in the vehicle, which I could use. So, off it goes.
The only real thing of interest is slightly elevated silicon, which, once again, I attribute to sealants in the engine, not bad air filtration like the report suggests. You can see the same pattern on the last 10K run. I also saw the trend in my 2006 Tundra as well.
I do have some general observations that I plan to post in oil analysis general questions forum.
#3450655 - 08/09/14 02:52 PM Re: 2011 Tundra, Amsoil signature 0W-20, 9.5K miles [Re: btanchors]
lubedude13 Offline
Loc: North Carolina
Looks good.
2010 Toyota Camry:
Amsoil Signature Series 0W20
Amsoil Signature Series Trans Fluid
Amsoil ATF Power Steering Fluid
#3451170 - 08/10/14 06:36 AM Re: 2011 Tundra, Amsoil signature 0W-20, 9.5K miles [Re: btanchors]
HKPolice Offline
Loc: Toronto, Canada
Viscosity is starting to creep up with 10k mile changes compared to the 5k mile results. This means the oil already oxidized quite a bit and most of the lighter elements have burned off already. Personally I wouldn't use it past 8k miles.
#3451212 - 08/10/14 07:43 AM Re: 2011 Tundra, Amsoil signature 0W-20, 9.5K miles [Re: btanchors]
btanchors Offline
Loc: Herndon, VA
HKPolice,
I'm inclined to agree with you - the TAN for both the ~9.5 - 10K intervals is one point above the virgin TAN (4.6). Although I do believe it was time to change out this oil, I don't really see it necessary to cut back the interval to 8K miles, though.
#3451227 - 08/10/14 08:10 AM Re: 2011 Tundra, Amsoil signature 0W-20, 9.5K miles [Re: btanchors]
HKPolice Offline
SAE 20 specs a max of 9.29 cST @ 100C, both 10K mile samples are above that. While running a thicker oil may or may not not increase wear, it does make the engine run hotter & increase oil pressure. Thicker oil doesn't flow as well so hotspots in the engine are allowed to get hotter, its simple physics. Doesn't really matter now that the truck is gone but these results prove to me that Amsoil Signature can not do the claimed 15K mile interval without a higher risk of increased engine wear.
Originally Posted By: btanchors
HKPolice,
#3451233 - 08/10/14 08:20 AM Re: 2011 Tundra, Amsoil signature 0W-20, 9.5K miles [Re: HKPolice]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
What a load of manure. First of all the oil starts at 8.8 cSt. Then you write "Viscosity is starting to creep up" and make allegation that "the oil already oxidized quite a bit and most of the lighter elements have burned off already." You make a 9.3 cSt oil seem like it is tar! I've run (as plenty of other people have) 10-12 cSt motor oils in Toyota V6's with better wear numbers than 9 cSt.
But let's keep it simple. Prove to us that a 9.3 cSt causes more wear than a 8.8 cSt oil. Because that is what you wrote.
