I'm not real well educated on shear and wear properties of oil but I assumed that M1TD would have to handle things like shear pretty good to do so well in my diesel suburban. The viscosity spread is the same as in RT6 5w-40 and a lot of guys use that for the life of their bikes, changing oil at 4k to 8k intervals. I like changing my oil at no more than 4k intervals regardless of how good it is. I've used RT6 and M1TD both in my diesel suburban before, and while they both make the engine run quiet when the oil is new, It's still almost as quiet after 1000 miles with M1TD, not as quiet with RT6 after same amount of miles. Or Maybe that's not representative of anything.? Does the MC specific grade synthetics such as amsoil or M1_4T handle shear any better than the HDEO's ? Sure a big difference in cost - again, just looking to learn here.
While I'm at it, I want to throw in that I have an 84 F150 that I bought new with 330k miles on it. 351 4VHO. I had it rebuilt at 275k miles due to a bad leaking rear seal plus my inexperienced driver teenage son letting it run too low on oil some years back. I'm using M1TD in it now, but for it's first 200k or so miles it got nothing but Castrol "Turbo Approved" SAE 30 dino oil. Also had a 84 Buick skyhawk 4 cylinder - my other son wrecked it about 10 years ago with 275k miles on it and it also got nothing but Castrol 'Turbo approved' 30 weight dino oil.
