Does my toyota camry have a wheel bearing problem? i haven't found the time to go to a tire shop, as i've been there and they said they needed several hours and i didn't have the time but my indy mechanic said I had a wheelk bearing problem and i needed it replaced and it would cost around 400 dollars. Is that typical? is it an easy DIY job (i herad it's not)
how would i know I need a wheel bearing replacement
and is it due to going on a lot of unpaved "gravel" roads at high speeds? or bumping into curbs?
what can I do to prevent this and what are some good tire/wheel maintenance things I can do to prevent this from happening so that I can have good wheels/tires despite the rough roads in michigan?
what are the symptoms of a bad wheel bearing? my wheel begins to make a strange noise after 20mph and it sounds like a helicopter
