zzyzzx Joined May 18, 2012 Messages 9,908 Location Baltimore, Maryland, USA Aug 8, 2014 #21 You should have the Mityvac just for testing for vacuum leaks and operating vacuum devices. I also use it to empty the master cylinder and refill with nee before bleeding to reduce the amount of time it takes to bleed the brakes.
