OK, "hard" on oil. What property of a XW-20 oil is most affected by an engine that is "hard" on oil? I thought it was about maintaining adequate oil pressure.
My 1MZ-FE is very hard on oil too. The gear driven camshafts shear the oil and the head temperatures are very high, especially in the rear bank. See my pictures somewhere on this site of the engine that visually show this, even when using a top-shelf synthetic oil at a relatively short OCI. So I would benefit from running a thicker oil than the 5W-20 I use? What benefit?
So the oil flows through a superhot bearing at ridiculous speeds. What does the thickness of the oil have to do with protection there? Isn't it more about the oxidation stability of the oil at that point? Or are you saying it won't lubricate the bearing properly?
When you made the statement about turbo engines I was sincerely asking what you meant. You could have picked a lot of other valid reasons for not wanting a thinner oil in an engine, but that was one I didn't understand why.
Originally Posted By: geeman789
Originally Posted By: kschachn
Can you explain how that makes a difference?
Originally Posted By: deven
Its not turbo'd like most new one nowadays
Turbo's are VERY HARD on oil ... it is the nature of the component. Oil flows thru a superhot bearing spinning at ridiculous speeds, and gets the [censored] beat out of it doing so...and the engines tend to run hotter as well, being higher power density than a normally aspirated motor.
The WRONG oil in some turbo app's will shear down very quickly ... SUBARU is one manufacturer who has SHORTENED OCI's on all turbo motors, stating they are SEVERE SERVICE applications, period...
