I got a new to me 2011 Impala, advice?
by gfh77665
07/23/16 02:15 PM
Guy drinks STP OIL TREATMENT
by FordCapriDriver
07/23/16 02:09 PM
2006 Hyundai Tucson - plastic in the pan
by OVERKILL
07/23/16 01:54 PM
AC = bad
by gman2304
07/23/16 01:51 PM
Refrigerator top light not working
by PandaBear
07/23/16 01:47 PM
EGR and braking
by otis24
07/23/16 01:45 PM
Replaced 109S with 114T; pressure recommendations
by George Bynum
07/23/16 01:40 PM
Old oil for edger oil change
by brian_06328
07/23/16 01:18 PM
Best Concealed Holster
by alanwayne1908
07/23/16 12:57 PM
Peak Global Life for 2010 Toyota Highlander V6
by mctmatt
07/23/16 11:58 AM
Michelin X Ice xi3 vs General Altimax Arctic
by Drew99GT
07/23/16 09:29 AM
Coat battery terminals with something or leave dry
by callbay
07/23/16 09:11 AM
SonofJoe, Axle_Needle, discobob, KHump, Zounds
58573 Registered Users
74 registered (02s4audi, alanwayne1908, Al, 01_celica_gt, AirgunSavant, 4WD, 6 invisible), 2061 Guests and 12 Spiders online.
58573 Members
66 Forums
252152 Topics
#3414535 - 07/04/14 01:40 PM Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi
SnPb Offline
Loc: Arizona
I thought that I would share the results of the last oil change on my Civic. The oil used was 3 qts of 5W-20 Pennzoil Platinum and 1 qt of 0W-20 Subaru branded Idemitsu SM that I had on hand. The Maintenance Minder was at 15% oil life remaining when changed. The previous fill was 100% Pennzoil Platinum 5W-20 for comparison.
I decided to use 5W-20 as opposed to 0W-20 as I don't think that there is a significant advantage to using the later in a climate where it rarely drops below freezing and is often quite hot. It would be good if the higher Viscosity Index were the result of a better base oil, but perhaps not so good if it is the result of a higher percentage of VI Improver in the mix.
This is the last oil analysis that I plan to perform on this car as the results appear acceptable to me, and I used my last Blackstone sample kit.
Cheers,
Jeff
OIL Penplat PenPlat Toyota Honda Univ
GRADE 5W20 5W20 0w20 0w20 Avg
MILES IN USE 7529 5782 6033 5742
MILES 28119 20860 15078 9045
SAMPLE TAKEN 5/18/14 11/24/136/9/13 11/10/12
ALUMINUM 14 16 25 14 8
CHROMIUM 0 0 0 0 0
IRON 7 6 12 8 8
COPPER 1 2 4 5 0
LEAD 0 0 0 0 0
TIN 0 2 1 2 1
MOLYBDENUM 61 63 185 662 72
NICKEL 0 0 0 0 0
MANGANESE 1 1 1 1 1
SILVER 0 0 0 0 0
TITANIUM 0 0 0 0 2
POTASSIUM 0 0 0 5 14
BORON 27 5 10 35 43
SILICON 16 17 26 45 16
SODIUM 4 7 5 0 44
CALCIUM 2224 2237 2220 1850 2104
MAGNESIUM 12 13 20 7 175
PHOSPHORUS 564 566 767 697 669
ZINC 661 633 934 839 774
BARIUM 0 0 0 0 0
SUS VIS 210F 48.9 51.3 52.2 51.4
cSt @ 212F 6.93 7.66 7.94 7.70
FLASHPOINT F 420 370 410 405
FUEL <0.5 <0.5 <0.5 <0.5
ANTIFREEZE 0.0 0.0 0.0 0.0
WATER 0.0 0.0 0.0 0.0
INSOLUBLES TR 0.1 0.2 0.3
TBN 4.6 2.6 2.6 0.2
FILTER Honda Purolat Honda Honda
A02 PL14610 A02 A02
#3414550 - 07/04/14 01:58 PM Re: Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi [Re: SnPb]
SnPb Offline
Loc: Arizona
I apologize for the lack of spacing in the table, but I couldn't resolve it before the post as locked and I could no longer edit it.
#3414556 - 07/04/14 02:04 PM Re: Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi [Re: SnPb]
SnPb Offline
Loc: Arizona
Code:
CHROMIUM        0       0       0       0       0
IRON            7       6       12      8       8
COPPER          1       2       4       5       0
LEAD            0       0       0       0	0
TIN             0       2       1       2       1
NICKEL          0       0       0       0       0
MANGANESE       1       1       1       1       1
SILVER          0       0       0       0       0
TITANIUM        0       0       0       0       2
BORON           27      5       10      35      43
SODIUM          4       7       5       0       44
BARIUM          0       0       0       0       0
TBN             4.6     2.6     2.6     0.2
                A02     PL14610 A02	A02
#3415033 - 07/05/14 07:03 AM Re: Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi [Re: SnPb]
Turk Offline
Loc: MN
The Toyota 0w-20 gave you lots more wear metals.
The PP/Oil Filters lowered your Insolubles. Which Oil Filters did you use?
I'd stay with PP. thumbsup
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3415037 - 07/05/14 07:14 AM Re: Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi [Re: Turk]
Trav Offline
Loc: MA, Mittelfranken.de
You heretic. LOL
#3415051 - 07/05/14 07:44 AM Re: Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi [Re: Trav]
Turk Offline
Loc: MN
You heretic. LOL
I know. crackmeup
gladiator
#3415132 - 07/05/14 09:40 AM Re: Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi [Re: SnPb]
Shannow Offline
Loc: Oz
Clearly the TGMO run was an issue with the engine, not the lubricant, as TGMO is the best that there is, and the only time that it doesn't looks so, there's another factor (the engine) at work...
Nice series of tests, and I concur with your conclusions.
#3415188 - 07/05/14 10:47 AM Re: Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi [Re: Turk]
SnPb Offline
Loc: Arizona
Turk, Honda A02 Filters were used, except a Purolator Pure1 was used with the first fill of Pennzoil Platinum.
#3448860 - 08/07/14 01:37 PM Re: Pennzoil Platinum 5W20, Honda Civic R18, 7259 mi [Re: SnPb]
HKPolice Offline
Loc: Toronto, Canada
I don't know why people keep repeating the myth that Honda engines are "easy on oil". This R18 sheared the oil from ~8.5 cst to under 7 cst after 7.5k miles on PP which is considered a top shelf synthetic.
While the TBN remained strong probably due a lot of highway trips, the oil took a hard physical beating to shear so much especially with no trace of water and minimal fuel dilution.
A less stout oil like bulk dino 5w20 would've probably sheared out of grade after 5k miles and caused excessive engine wear if ran to 0% OLM.
