MolaKule
Staff member
In a Falex Load-to-Seizure Test a series of base oils were tested using the same viscosities of base oils.
A polyol ester pure base oil of Pentaerythritol failed at 3,400 PSI.
Pure mineral oil failed at 22% of the Pentaerythritol, but PAO failed at 253% of the mineral oil.
At what PSI did the mineral oil and PAO fail?
Rules for the Question of the Day:
1. No Piston Cup Lapel Pin will be awarded to the same person within 14 days of a previous award.
2. Please respond with a complete sentence.
3. Please do not post links. If a question arises as to the need for clarification, then sources and links may be requested.
4. Please, no off topic posts.
