depends on the car. I had an 02 chrysler with 1.1V drop from battery to alternator if the lights were on. that's a pretty bad drop. tied battery, alt frame, intake manifold (there was 0.2V drop just from alt frame to engine block, for reasons I could never figure, under load), ECU frame, body, together on a continuous 12 gauge wire with soldered lugs and the voltage drop disappeared. the odd result was the transmission immediately shifted better-- quicker or more precisely... hard to describe, but a pleasant surprise. engine and accessories had no perceivable change. I think I also did the same thing to a honda accord that did not have more than 0.2V drop anywhere on the big grounds. As one might expect, it made no difference.
