Liqui Moly Motor Oil Saver?
Charlestown Indiana
Hello all! I have an 01 Ford Ranger (SOHC 4.0) that has what appears to be a "slight" (doesn't leave spots) rear main seal leak and I'd rather not pay $700+ to have it fixed. I've been running Mobil 1 High Mileage 5w-30 for about 20k, so I doubt that's going to solve the problem. Is the Liqui Moly product any good, or is there anything else you fine folks would recommend? Next month I've got a 10 hour road trip (Louisville KY to Destin FL), so I'd like something I could just dump in and forget about. By the way, I just changed the oil so I'd rather not fool with something that I'd have to dump after 500 miles. As always, thanks for any help!
I love lobro moly products, but I just solved this exact issue in my son's tired old Lincoln with Maxlife synthetic blend oil...
Originally Posted By: ARB1977
If your going to use the saver I wouldn't use a HM oil with it.
Why not, will the products comflict in some way?
I've been using M1 HM for the past 20k miles, I know Maxlife HM is an outstanding product but if a HM oil was going to solve the problem, I think the M1 would have pulled it off in the last few OCI's...
