Any experience with 98-02 corolla?
by barkingspider
8 minutes 13 seconds ago
nice video
by raaizin
42 minutes 42 seconds ago
Dumbest thing you have been told at a parts store
by tojo1968
48 minutes 39 seconds ago
Our cars are due for oil, any recommendations?
by MilesToEmpty
Today at 02:30 PM
roof shingles- come from oil?
by edwardh1
Today at 02:28 PM
2015 Honda Accord FF UOA 8350 miles
by dieselworld
Today at 02:09 PM
Mobil 1 has highest film strength
by DrRoughneck
Today at 01:10 PM
A guy at the gym.....
by Doog
Today at 12:26 PM
Fram xg3976a or wix 57620 for 5.9l cummins?
by monster1
Today at 11:52 AM
Fram XG2 vs Motorcraft 820s
by doolah02
Today at 10:57 AM
06 Elantra rough start up
by dan765
Today at 10:52 AM
Grand old ship...new life?
by andrewg
Today at 10:29 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
105 registered (2015_PSD, 2oldtommy, 97K15004WD, 05LGTLtd, 90crvtec, adelody, 11 invisible), 1719 Guests and 127 Spiders online.
56834 Members
66 Forums
244270 Topics
#3444415 - 08/03/14 05:25 AM Long drain oil filters without ADBV?
NMBurb02 Offline
Loc: Crowntown, CA
I am interested in running an extended OCI capable oil filter for multiple OCIs on the Burb (currently doing 4-5k OCI w/ G-Oil) for both the economics of it and to take advantage of the performance specs of those filters. However, I would like to be able to drain the filter to get as much of the old oil out. I admit that is probably a bit OCD, but isn't that why BITOG is around? The filter on the Burb is mounted vertically with the base facing up, so an ADBV is unnecessary in this application. However, the FU, D+, and PS all have ADBV.
So, are there any extended drain oil filters without ADBV? Particularly any for a 2002 Chevy Suburban 5.3L V8?
2002 Chevy Suburban 1500, G-Oil 5W-30, Fram TG3675
2006 Pontiac Grand Prix GT, M1 0W-40, Fram TG3387A
#3444418 - 08/03/14 05:45 AM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
sayjac Offline
Loc: The Old North State
First I'd say that your assumption that because the filter sits in a vertical thread end up orientation it doesn't require a adbv, is inaccurate. As much as holding oil in the filter an adbv also allows oil to be retained in the galleries above the filter, reducing dry start/start up rattle. If the vehicle manufacturer specs's an adbv they do so for a reason and using a filter without one would not be advisable.
Second, the small amount of oil retained in filter, perhaps ~4-5oz. is not going to make any significant difference in engine wear/life over getting every last drop of oil out of the filter. And most on this board will advise you that best practice when reusing a filter is to leave the filter in place as the sealing gasket could be compromised with removal.
If you can't live with the small amount oil left in the filter then perhaps using a lower tier filter for the 4-5k oci would be more advisable and just as cost effective. But that's your call.
But to answer the question, I know of no filter with no adbv that fits this application.
#3444435 - 08/03/14 06:26 AM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
Donald Offline
Loc: Upstate NY
Do not worry about the oil in the filter, not significant. And I agree, do not remove the filter and then reinstall.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3444461 - 08/03/14 07:30 AM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
yvon_la Offline
Loc: quebec canada
Horizontally mounted oil filter can skip adbv if they use 0w20 ,all other require adbv .sorry
Truck driver
Nissan versa note s 2014
Mechanicly inclined
#3444477 - 08/03/14 07:53 AM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
CELICA_XX Offline
Loc: Oklahoma
It's not like the filter is made specifically for your car.
It also fits a hundred other motors.
Why do you feel like the ADBV is bad ?
15 Toyota Prius - M1 EP 0w20 / K&N
02 Toyota ECHO - PU 5w30 / Wix
97 Lexus LX450 - M1 0w40 / FU
93 Lexus LS400 - Valvoline MaxLife Full Syn 5w30 / FU
#3444495 - 08/03/14 08:16 AM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
sicko Offline
Loc: Virginia
I don't know how much truth there is to it or not, but I was always told that once you loosen your filter, it needs to be removed. That the gasket seal is compromised and wont form as tight a seal again.
I've always followed that, but I also have never had any reason to loosen a filter unless I was removing it.
#3444496 - 08/03/14 08:17 AM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Hot oil can still drain out of a vertically mounted filter that's above the sump (siphon action)-think of the ADBV as an insurance policy, especially a silicone one-you'll get oil pressure a lot faster on a cold start.
06 Ram 3500 CTD 4X4 48RE SRW, 93 GMC C3500 6.2 diesel, 89 F-450 7.3 IDI, 98 Cherokee 4.0, 05 Scion xB, 15 Transit 250 3.7
#3444515 - 08/03/14 08:40 AM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
Rhymingmechanic Offline
Loc: VA
At one time, ACDelco PF61 had no ADBV. However, that is now an E-core filter, and NAPA cross references it to their 1522 which does have the ADBV. Your truck probably specs the discontinued PF59 that also crosses to 1522.
I'm with those who say there's no reason to omit the valve. My guess is that it would cause startup noise. Pick your filter for its long-drain capacity and sleep well. I have even run ACDelco classic filters up to 7 and 8,000 with no problems.
#3444525 - 08/03/14 08:48 AM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
gregk24 Offline
Loc: FL, USA
Not a good idea, if your engine specs an ADBV then you need one. Oil will drain out of the galleries without one. No need to drain the filter, its such a small amount of oil and the o ring can lose its seal.
2012 Honda Accord EX-L 36K
M1 AFE 0w20 / Fram Ultra
2005 Chevy Uplander 133K
QSD 5w30 / Fram Ultra
1991 Buick Park Avenue 120K
Supertech 5w30 / Fram Ultra
#3445201 - 08/03/14 10:42 PM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Note that the Wix filter for the small block Chevy still specifies no ADBV (and no bypass valve, of course).
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3445250 - 08/03/14 11:52 PM Re: Long drain oil filters without ADBV? [Re: NMBurb02]
ZeeOSix Offline
Loc: PNW
^^^ Wix for the LS1/LS6 does have the ADBV, and the filter mounts in the same place as any old small block from GM. Perfectly vertical on driver's side, rear of engine with base plate up.
A filter's brand name doesn't matter ... what's inside does.
#3445277 - 08/04/14 01:46 AM Re: Long drain oil filters without ADBV? [Re: ZeeOSix]
Garak Offline
Yep, I checked both Wix filters to compare. wink
#3445294 - 08/04/14 04:09 AM Re: Long drain oil filters without ADBV? [Re: yvon_la]
ac_tc Offline
Loc: sweden
- what??
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3445345 - 08/04/14 07:17 AM Re: Long drain oil filters without ADBV? [Re: yvon_la]
zrxkawboy Offline
Loc: SD
Another pearl of wisdom, folks...be sure to write these down and keep them in a safe place.
"Think of all the Ford owners who will someday want an automobile." John Dodge
