2002 GMC Yukon Climate Control Problems
by Kgrant
13 minutes 10 seconds ago
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
Today at 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
Yesterday at 11:08 PM
GM Oil Life Update
by CapitalTruck
Yesterday at 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
Yesterday at 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
Yesterday at 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
Yesterday at 08:48 PM
why would someone want to pay with a phone?
by turtlevette
Yesterday at 08:16 PM
The connection was reset problem
by Triple_Se7en
Yesterday at 08:14 PM
BIG PROBLEM!
by Avery4
Yesterday at 08:03 PM
11,000 miles on a BMW
by BigJohn
Yesterday at 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
Yesterday at 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
42 registered (AutoCoil, asand1, bbhero, akela, AJP, 4 invisible), 611 Guests and 204 Spiders online.
56834 Members
66 Forums
244295 Topics
#3444354 - 08/03/14 12:18 AM comp monitor flickers every minute or 2...
daves66nova Offline
Loc: los angeles
I've been noticing that recently, my monitor's display flickers every minute or so.Is there a setting that might I can adjust for this? It's an Asus 19".
THIS SPACE FOR RENT, PLEASE PM ME.
#3444405 - 08/03/14 04:51 AM Re: comp monitor flickers every minute or 2... [Re: daves66nova]
Noobie Offline
Loc: None
Could be the drivers or the graphics card.
Update your drivers to the latest stable version and see if it goes away.
Edited by Noobie (08/03/14 04:52 AM)
03 BMW 525i M54 - / Everclear 10W-30
10 BMW 530i N52K - / MaxiGuard 10W-40
12 Audi A6 V6 2.8FSI - / Orbit 10W-40
15 Toyota LC Prado 1KD-FTV - /
#3444414 - 08/03/14 05:24 AM Re: comp monitor flickers every minute or 2... [Re: daves66nova]
Lolvoguy Offline
Loc: Canada
what model of monitor?
07 Focus ZX4 SES - Automatic
03 Suzuki SV650S
88 325is - 5 speed manual
Originally Posted By: Clevy
Ultimately my car is an appliance bought to serve me.
#3444431 - 08/03/14 06:17 AM Re: comp monitor flickers every minute or 2... [Re: daves66nova]
Lubener Offline
Loc: Ohio
I doubt a driver would cause an intermittent problem like this.A driver issue would not start to cause an issue after everything worked good previously.Is this a CRT or a panel?
Edited by Lubener (08/03/14 06:19 AM)
The "thinking" man's friend.
#3444508 - 08/03/14 08:30 AM Re: comp monitor flickers every minute or 2... [Re: daves66nova]
fdcg27 Offline
Loc: OH
Probably time to look around for a new monitor.
If you have a known good monitor sitting around, try it and see if the problem goes away.
If not, then you have an issue related to either software, something on the motherboard or the motherboard itself, which I realize isn't very helpful.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3444679 - 08/03/14 12:14 PM Re: comp monitor flickers every minute or 2... [Re: daves66nova]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
My AOC monitor did the same thing for almost a month, even after making sure my Windows Shockwave Flashplayer was always updated.
Then one day I did a full scan with C-Cleaner. I suspect it removed a bug in my Registry that caused it.
Ever since I did that 'full' C-Cleaner cleanup, no more monitor flickering.
#3444681 - 08/03/14 12:16 PM Re: comp monitor flickers every minute or 2... [Re: daves66nova]
ToyotaNSaturn Offline
Loc: Spring Hill, TN
Change the resolution and frequency. If a flat panel, try 59 or 60hz on a different display setting. Often times this works as the long term solution.
2006 Mercury Montego, V6
2004 Saturn Vue, V6
#3446283 - 08/05/14 03:42 AM Re: comp monitor flickers every minute or 2... [Re: daves66nova]
Noobie Offline
Loc: None
I had a similar problem like a week ago.
My monitor was not flickering but for some reason it was freezing and turned completely black for 1 second and then it worked properly again. This happened every couple minutes and at the end i just uninstalled the drivers, did a reg clean with CCleaner, used a special tool to clean old driver files and installed the latest stable release.
No problems so far.
#3446672 - 08/05/14 12:12 PM Re: comp monitor flickers every minute or 2... [Re: daves66nova]
ThirdeYe Offline
Loc: Walker, MI
It wasn't with my PC, but when I first got my PS3, it was trying to output a 1080p signal to my 720p TV. It would work intermittently and randomly turn black and come back on again every so often. I changed it to output 720p instead and I haven't had the issue since. I also have issues with my sound coming and going (handshake issue?) where I have to turn my TV off and on again to get it to come back.
99 Pontiac Firebird - 91k - Pennzoil Platinum 5W-30/Fram Extended Guard XG3980
08 Scion tC - 112k - RP 0W-20/Fram Ultra XG4967
#3448001 - 08/06/14 03:07 PM Re: comp monitor flickers every minute or 2... [Re: ThirdeYe]
ironman_gq Offline
Loc: MN
How did that work? Usually anything plugged into HDMI will automatically set the resolution to whatever the native is on the TV.
#3448727 - 08/07/14 10:12 AM Re: comp monitor flickers every minute or 2... [Re: ironman_gq]
ThirdeYe Offline
Loc: Walker, MI
No clue, I suspect it had something to do with the auto-setup on the PS3, but it hasn't done it since I switched the resolution within the system back to 720p. Placebo effect? Perhaps...
#3449019 - 08/07/14 04:09 PM Re: comp monitor flickers every minute or 2... [Re: ThirdeYe]
What is the difference between 'native' and 'default'?
