Making tacos at home
by Reddy45
07/25/16 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
07/25/16 11:38 AM
Power Steering Fluid
by DWC28
07/25/16 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
07/25/16 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
07/25/16 08:05 AM
kohler courage 15 issues
by tomm22
07/25/16 07:58 AM
Small overlap crash test?
by Huie83
07/25/16 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
07/25/16 07:20 AM
Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
96 registered (Andrei, Al, 182RG, 3Phase, Alfred_B, ABerns, 3 invisible), 1869 Guests and 15 Spiders online.
58589 Members
66 Forums
252230 Topics
#3432516 - 07/22/14 04:50 PM Campy crank threads L. or R. thread?
daves66nova Offline
Loc: los angeles
I'm planning to disassemble my bike and i've read that some crank bolt threads are opposite,meaning counterclockwise tightens them. Does anyone here know what they are? I have Camy Nuovo Record. thanks
THIS SPACE FOR RENT, PLEASE PM ME.
#3432535 - 07/22/14 05:06 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
Wheel Offline
Loc: Upstate NY
According to Barnett's Manual, ALL crank bolts are regular right hand thread. Bottom brackets (except Italian threaded ones) and pedal axles are the usual ones that use left hand thread at all.
Theory was that regular movement of the components could cause loosening. I can't say I've seen that on the one bike I have with a bottom bracket threaded that way.
#3432594 - 07/22/14 06:06 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
oliveoil Offline
Loc: snow and sun
The bolts that hold the crank arm on are 14 or 15mm and are regular right threaded. But you need a "crank arm puller" to take the crank arms off. Then the Bottom bracket (BB) can be disassembled. You will need some bottom bracket tools also. Any bike shop can sell you these tools. The left side of the BB, the non drive side, as you are sitting on the bike looking down, is normal right hand drive and this is the only side that needs to be removed when overhauling the BB. Hope this helps.
#3433527 - 07/23/14 03:31 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
dailydriver Offline
Loc: Bucks County, Pa.
It's been a LONG time since I've had/worked on regular, old school style Campy cranks and bottom brackets.
I always remember having to use at least the red LocTite on the crank bolts in order to hold them in place, and not loosen up to the point that they destroyed the softer than the axle, tapered crank openings.
I still have my Campy "peanut butter" spanner which was used on these bolts amd also my track bike's Campy hub bolts. wink smile
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3433953 - 07/23/14 11:21 PM Re: Campy crank threads L. or R. thread? [Re: oliveoil]
teddyboy Offline
Loc: NC, United States
[quote=oliveoil]The bolts that hold the crank arm on are 14 or 15mm and are regular right threaded. But you need a "crank arm puller" to take the crank arms off. Then the Bottom bracket (BB) can be disassembled. You will need some bottom bracket tools also. Any bike shop can sell you these tools. The left side of the BB, the non drive side, as you are sitting on the bike looking down, is normal right hand drive and this is the only side that needs to be removed when overhauling the BB. Hope this helps. [/quote.
I do not agree that you only need to loosen the non-drive side. To properly clean out and re-grease the bottom bracket, you really need to remove both cups.
97 Camry M1 5W30 HM & OEM Filter
14 Camry TGMO 0W20 & OEM Filter
08 Volvo S60 M1 0w40 OEM Filter
#3443168 - 08/01/14 06:32 PM Re: Campy crank threads L. or R. thread? [Re: teddyboy]
oliveoil Offline
Loc: snow and sun
Not really. This is why we have dexterous fingers and opposable thumbs. One should always check the drive side cup for tightness.
#3443181 - 08/01/14 06:48 PM Re: Campy crank threads L. or R. thread? [Re: oliveoil]
dailydriver Offline
When I had these, I used to open up the drive side cup for a total cleaning every other repack. wink
M1-206 oil filter
#3444744 - 08/03/14 01:44 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
daves66nova Offline
Loc: los angeles
I ended up taking it to a good bike shop. They charged me 15.00 to completely take apart the cranks and everything else there and the headset. ON TO PAINT NOW!!
#3444929 - 08/03/14 05:53 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
dailydriver Offline
That's not bad for all of that, especially in So-Cal. wink
M1-206 oil filter
