Got me a new Stihl FS 56 trimmer today
by daddi
08/30/16 01:02 PM
Truck cap lights.
by wolfehunter
08/30/16 12:12 PM
filters and oem specs
by mobilaltima
08/30/16 11:50 AM
H11 bulb options
by asiancivicmaniac
08/30/16 11:47 AM
Engine oil accidently added into transmission
by Mazatrol
08/30/16 09:51 AM
Oil for 1996 Mazda B4000 pickup
by schuylkill
08/30/16 09:16 AM
Shell gas $80 rewards cars for $52 Deal ends 9-1
by gojoneeded
08/30/16 09:12 AM
Cleaning a carpet stain....Help!
by mjk
08/30/16 07:39 AM
Windshield: can it be repaired?
by supton
08/30/16 07:12 AM
Sea foam for my car?
by NavyVet88
08/30/16 07:04 AM
Anyone have experience with Chinese stereos?
by 55Test
08/30/16 06:37 AM
A 14.5 billion dollar bill for Apple
by Pop_Rivit
08/30/16 05:58 AM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
81 registered (Alfred_B, asiancivicmaniac, ARCOgraphite, 87sammy, 74Scout, 09_GXP, 7 invisible), 1633 Guests and 9 Spiders online.
58964 Members
66 Forums
253772 Topics
Page 3 of 4 < 1 2 3 4 >
#1217620 - 08/16/08 11:47 AM Re: ATF Fluids [Re: Jimbo]
bmwtechguy Offline
Loc: South Carolina
I saw RP 75W-140 at AZ for $16/qt
#1431502 - 04/10/09 10:34 PM Re: ATF Fluids [Re: bmwtechguy]
gamefoo21 Offline
Loc: Kah-nah-dah
Slam the ATF in an engine all you want. But what I know is, and from what I've experienced is...
Dumping a litre into the crank will do [censored] all.
Dumping out the old oil, refilling with a nice synthetic ATF and maybe a tin of engine flush, with a new filter on a engine that has been running amsoil 5w30.
Resulted in one plugged filter hitting the bypass after 2 minutes of alternating the idle. The ATF that went in cherry red, came out black like tar, stank like rotting gym socks, and the refill of Redline 5w30 stayed clear for 800-1000km.
It's like All Bran but for your engine.
#1639808 - 10/21/09 07:28 AM Re: ATF Fluids [Re: benjamming]
karan Offline
Loc: India
which the base oil is used for ATF
#1656834 - 11/03/09 02:34 PM Re: ATF Fluids [Re: karan]
MolaKule Offline
Loc: Iowegia - USA
Quote:
which [what is] the base oil is used for ATF
The base oil for non-synthetic ATF's is GroupII or II+ ; usually used for DexronIII/Mercon and Universal run-of-the-mill ATFs. They usually start out with a 4 cSt base oil and thicken it with Viscoity Index Improvers or VIIs.
It's the thin viscosity, rather than the additives that gives it a flushing effect. I would not use ATF either by itself or with a can of motor flush to clean an engine. There is low-level anti-wear additive package in these fluids but not suited for engines. I prefer to use frequent oil changes and or ARX.
For GM's DexronVI it is GroupIII. For full-synthetic ATFs such as Redline, Amsoil, and Mobil, they use predominately PAO's with low dosages of GroupIV compounds.
We have to stop saying: "How stupid can you be?" Too many people are seeing that as a challenge. smile
#1663941 - 11/08/09 10:02 PM Re: ATF Fluids [Re: MolaKule]
Ken2 Offline
Loc: Washington St.
Some motorcycle riders use ATF as a lube for their o-ring chains. (O-ring chains have an o-ring between the side plates to seal lube between the pin and bushing. The bushing-to-roller interface and the roller-to-sprocket still need lube.)
So...would ATF be much good for this given the small amount of AW and no EP in it, or is it working just because some lube is better than no lube, and ATF isn't sticky and won't hold much grit?
There are perpetual discussions of chain wax lube, chain sticky lube, gear oil, used engine oil, WD-40, chainsaw bar & chain oil (very tacky), and dry lubes like DuPont Teflon Multi Purpose spray, dry spray with moly & graphite in a volatile penetrant, and others.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#1664886 - 11/09/09 06:19 PM Re: ATF Fluids [Re: Ken2]
MolaKule Offline
Loc: Iowegia - USA
That's about it.
#1751307 - 01/22/10 08:03 AM Re: ATF Fluids [Re: MolaKule]
ray_ray Offline
Loc: WA, usa
Interesting thread...
One more question as I can't follow all the details here
How would ATF rate when used as the transmission oil for a 2-stroke motorcycle engine?
#1751371 - 01/22/10 08:55 AM Re: ATF Fluids [Re: MolaKule]
ray_ray Offline
Loc: WA, usa
I just asked the question about 2-strokes bikes using this oil in their transmissions but after re-reading this part about using VIIs here is news to me also and I'd guess ATF fluid is suspect to shear breakdown just like a multi-grade motor oil... And it starts life with the lower grades oil types.
Is this true of the true synthetic (non crude ) ATF fluids?
Plus I'm not sure about the 4 cSt to viscosity conversation but this sounds an ATF starts life at a very low wt.
PS -- I don't mean to crash UR thread here but you guys seem to know your stuff on ATF fluids.
Edited by ray_ray (01/22/10 08:59 AM)
#1753430 - 01/24/10 02:17 AM Re: ATF Fluids [Re: ray_ray]
MolaKule Offline
Loc: Iowegia - USA
One could use a DexronVI type fluid since the shearing has been shown to be almost zip if you are worried about shearing.
One the other end of the scale is the High Mileage ATF's which start out with a higher viscosity.
Edited by MolaKule (01/24/10 02:19 AM)
#1941893 - 07/03/10 07:17 PM Re: ATF Fluids [Re: bmwtechguy]
emaax Offline
Loc: Portugal
Originally Posted By: bmwtechguy
I saw RP 75W-140 at AZ for $16/qt shocked
teh average factory price of the barrel of 4L (4qt?) of 100% syntetic is 100
google Tabela_Precos_Castrol_Distribui_PVP2008.07.pdf
or 0000_tabelasPrecosPVP08_BP_3.pdf
and you see the kind of oil prices are recommended around here portugal (europe)
for the 100/4L get it by 70 in supermarkets
on ebay and other sites one can get better prices
by looking at the references... one can also see what oils are syntetic and mineral
#3440015 - 07/29/14 08:44 PM Re: ATF Fluids [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
BTW, The Boron is an agent separate from the dye.
In some cases, the dispersant used in an ATF is an ashless dispersant which has been phosphorylated and/or boronated with a hydrocarbyl succinimide, which give rise to the Boron and Phosphorous counts.
A small amount of ZDDP may also be used as a primary anti-oxidant.
#3443039 - 08/01/14 04:17 PM Re: ATF Fluids [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
From Question of the Day:
The clutch disc material of Automatic Transmissions, and other wet clutch applications, are made of porous friction materials which are bonded to steel core plates.
Friction materials may include cellulose, carbon fiber, Aramids, fiberglass, or a combination of materials (composites).
Today, composites rule.
Note: Sintered metal composites may be found in HDD applications.
This material must exhibit:
1.) Mu(o), low speed dynamic coefficient; affected by friction material ingredients and ATF additives adsorption
2.) Mu(i), initial dynamic coefficient at high speed; affected by hydrodynamic effects/porosity/compression/roughness.
#3469832 - 08/31/14 07:41 AM Re: ATF Fluids [Re: MolaKule]
RamFan Offline
Loc: Illinois, U.S.A
Interesting thread, nice to see informative posts on BITOG again. Mola, what exactly makes ATF +4 so special? From my understanding of the ATF world, most ATFs are some form of Dex/Merc with tweaks made to meet various OE demands. However, ATF +4 is a different breed. I've read AllPar's page on the development of the product but I guess I'm missing the "why" of it's speciality.
06 Monte Carlo LT
+3.9l V6 - 177k - Super S Multi-Flo 5w30 - Napa Silver - OLM
16.5 CX-5 Touring
+2.5l I4 - 10k - Mobil Super 0w20 - Fram Ultra - OLM
#3470116 - 08/31/14 02:36 PM Re: ATF Fluids [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
ATF + 4 has a slightly different Mu(v) (static/dynamic COF) curve verses DexronIII/Merc, and a low Brookfield viscosity spec.
#3484700 - 09/16/14 07:27 PM Re: ATF Fluids [Re: MolaKule]
Leeeeeee Offline
Loc: Ontario,Canada
Which means what?
