Ugly New Prius #2
by AirgunSavant
08/28/16 08:32 AM
Getting hurt at work
by ram_man
08/28/16 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
74 registered (4WD, 09_GXP, 2010Civic, 2015_PSD, 2009Edge, 2004tdigls, 5 invisible), 1283 Guests and 25 Spiders online.
58943 Members
66 Forums
253659 Topics
#3442104 - 07/31/14 06:51 PM Amsoil AFL or EFM for 2002 MB ML320
bimmerdriver Offline
Loc: British Columbia, Canada
I have a 2002 ML320. I've put 30k kms on it. (Currently 98k kms on the odometer.) For the first oil change after I purchased it, I put in Amsoil AFL, which they are now calling mid-saps. (I realize the vehicle does not call for oil meeting MB 229.51, but I had some of this oil for another vehicle, so I used it.) I used an OEM synthetic oil filter. Also, not long after I purchased the vehicle, the rear main seal started leaking and eventually got bad enough to require replacement. I ran the AFL oil for two oil change intervals. For the most recent oil change that was done after the rear main seal was changed, I put in Amsoil EFM which they are calling full-saps. Initially, with the leaking rear main seal, I couldn't tell if the vehicle was using oil (as opposed to leaking it), but lately, with the real main seal fixed, it appears to be using oil, approximately 1 l per 1000 km, which in my opinion is excessive. Is it possible using AFL instead of EFM could have contributed to oil consumption?
2002 BMW M3 (mine)
1997 BMW 328is (sold)
2002 MB ML320 (hers)
2004 VW GTI (son)
#3442283 - 07/31/14 10:01 PM Re: Amsoil AFL or EFM for 2002 MB ML320 [Re: bimmerdriver]
brandini Offline
Loc: Richmond, VA
no
07 Mazda3s Hatch - ZoomZoom - Using EAO-ALM-BF3-MTG-ANT-ATF
#3445884 - 08/04/14 05:12 PM Re: Amsoil AFL or EFM for 2002 MB ML320 [Re: bimmerdriver]
BrianC Offline
Loc: Central Florida
Did you you change spark plugs? Are the recessed? If so, did you ensure ALL debris was removed PRIOR to removing plugs? IF not, you may have allowed dirt,sand, etc,. to fall into the combustion chamber, consequently scoring the cylinder walls.
'14 Santa Fe Sport 2.4L
#3446273 - 08/05/14 01:34 AM Re: Amsoil AFL or EFM for 2002 MB ML320 [Re: BrianC]
I did change the spark plugs (all 12), but I used a compressor to blow around them first. The engine is quite clean, so I don't think any debris got into the cylinders. I have heard that these engines can require valve seals.
2002 BMW M3 (mine)
2004 VW GTI (son)
#3450630 - 08/09/14 02:22 PM Re: Amsoil AFL or EFM for 2002 MB ML320 [Re: bimmerdriver]
I talked to a mechanic who works on MBs and other German cars. He contacted an MB service technician who said there is well-known problem with these engines where scoring occurs on the thrust side of the even numbered cylinders, usually cylinder 2 or 4. They recommend looking in the cylinders with a borescope to see if there is scoring. I don't have a borescope, but I did save some oil to send to blackstone for analysis.
2002 BMW M3 (mine)
2004 VW GTI (son)
