Posting this for someone else.
Comments/questions?
Report Date: 07/28/14
Unit ID: 11 ACADIA
Lab No.: G24522
Fuel Type: Gasoline (Unleaded)
Oil Type & Grade: ACDelco Dexos Synthetic Blend 5W/30
Make/Model: GM 3.6L V-6 (LY7)
Sample Date: 07/24/14
MI/HR on Oil: 3,079 MilesMI/HR on Unit: 31,456 MilesMake Up Oil Added: 0 qts
Comments: Thanks for the notes. You mentioned the oil life monitor said about 43% was remaining and it was probably right; this oil could've seen more use. Universal averages show typical wear levels for this type of GM engine after about 5,300 miles of oil use. You didn't go that long on this fill, which is probably why iron (steel) read lower. It's the only metal that should increase with miles on the oil, while the others remain relatively close to average. The viscosity was low for a 5W/30 and read in the 5W/20 range. The TBN was strong at 3.2, so try 5,000 miles next. Nice!
Code:
ELEMENTS PPM UNIVERSAL AVERAGES
ALUMINUM 2 5
CHROMIUM 0 1
IRON 15 23
COPPER 3 9
LEAD 0 1
TIN 3 1
MOLYBDENUM 41 68
NICKEL 0 1
MANGANESE 1 10
SILVER 0 0
TITANIUM 2 0
POTASSIUM 3 2
BORON 8 38
SILICON 8 15
SODIUM 28 48
CALCIUM 2268 1978
MAGNESIUM 22 218
PHOSPHORUS 690 688
ZINC 825 813
BARIUM 0 0
PROPERTIES. Values Should Be*
SUS Viscosity @ 210° 53.0 56-63
cSt Viscosity @ 100°C 8.19 9.1-11.3
Flashpoint in °F 430 >365
Fuel %
Antifreeze % 0.0 0.0
Water % 0.0
Insolubles % 0.2
TBN 3.2 >1.0
TAN
ISO Code
Comments/questions?
Unit ID: 11 ACADIA
Lab No.: G24522
Code:
ALUMINUM 2 5
CHROMIUM 0 1
IRON 15 23
COPPER 3 9
LEAD 0 1
TIN 3 1
MOLYBDENUM 41 68
NICKEL 0 1
MANGANESE 1 10
SILVER 0 0
TITANIUM 2 0
POTASSIUM 3 2
BORON 8 38
SILICON 8 15
SODIUM 28 48
CALCIUM 2268 1978
MAGNESIUM 22 218
PHOSPHORUS 690 688
ZINC 825 813
BARIUM 0 0
Fuel %
Water % 0.0
Insolubles % 0.2
TBN 3.2 >1.0
TAN
ISO Code
