okay today I changed my transfer case oil in my Jeep grand Cherokee 07 CRD
I have been getting a service 4wd on the screen
I replaced the front and rear diff electronic actuators as well as harnesses pulled the covers washed the diffs out and then filled with redline shockproof heavy so far so good
Its been a couple months and I started to get the same notice again on the screen
I took it to the dealer and he said the clutch in the transfer case was engaging to far
I decided to change the transfer case fluid first as the forums say change it every 40,000k,s its done 70,000k,s
The book does not say that and neither does the dealer after changing the oil I noticed it had ATF fluid in it and that its supposed to have a different type of oil in the transfer case so rather than stuff around I filled it with genuine Mopar oil
the ATF that came out was full of what looks like clutch particles so I am not happy
After speaking to a transmission specialist he recommended driving it for a while
I am going on holidays with it about 4 thousand K,s he said when I come back drop the oil and put it in a white container and see what's in it we can go from there needless to say not impressed with this I hear from some circles to use Mobil tractor oil or CVT transmission oil in it I would like some opinions on that
Also how much damage have I done with the incorrect oil
